trying to remove pedal assembly
    hey i'm trying to put in new bushings for my pedals but
    can't take the assembly.
    it's a 90 airbag car idk if that matters.
    looks like i need to drop streering shaft to get to the last
    two bolts because it is impossible to get a spanner on there.
    See those bolts? there is no head on there to unscrew and drop the shaft.
    how can i do this? the nut on the back looks like it's welded on.
    thanks for the help i'm stumped as shit right now.
    :rippedoff:
    Wat?? by jet jones, on Flickr
    Tried a crowfoot wrench?
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
      Those cone shaped bolts without heads are security bolts, the head breaks off after they are tightened. I usually slot them and use an edged tool to unscrew them.
      BMW calls them fracture bolts.
      https://www.ecstuning.com/b-genuine-...t/32311152054/
        just for future people.
        i tried to hand chisel it loose, vice grips. nothing worked.
        vice grips where only able to grab the washer.
        What you need to do is get an air hammer with V chisel and it'll spin itself loose
        then use vice grips on the damaged head.
        Safety bolt by jet jones, on Flickr
        this is the bolt that needed to come out.
        a crowfoot worked on the right one but left one there was no room.
        Pedal assembly by jet jones, on Flickr
