The suspension setup/ride height thread
    front
    * E36 5 lug swap with custom made coil-overs to fit E30 strut inserts
    * Bilstein Sport shocks race valved and paired to match spring rate
    * Hyper Coil 500 lb springs 5 inch length
    * e30 21mm Convertible sway bar
    * E30 M3 sway bar end links
    * TreeHouse Control Arm Bushings
    * sparco strut bar
    * GC adjustable camber plates
    rear
    * coil-over adjuster
    * Eibach 650lb, 2.5" diameter 6 inch length
    * stock rear sway bar
    wheels and tire
    * BMW Staggered DSIIĀ“s
    * Dunlop Star Spec Front 215/40/17 Rear 235/40/17
    * wheel studs
    FS:///M-Tech Wallets.
    http://www.r3vlimited.com/board/showthread.php?t=224601
      Kw v1 coilovers
      rear collars out maxed out
      front has 2 inches left
      ireland engineering camber plates
      and rear top mounts
      205/45/16 dunlop direzza
        Originally posted by e30abe89 View Post
        Kw v1 coilovers
        and rear top mounts
        http://i948.photobucket.com/albums/a...ps09627576.jpg
        Specs on wheels?
          front:
          HnR sport (cut one round, coz spring for 6cyl and mine 4cyl)
          e90 drop hat
          stock pad
          boge stock s/a
          rear
          HnR sport
          stock pad
          bilstein touring s/a
          alpina 16x8
          20mm spacer
          205/45/r16
          [ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
          [ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
          Transaction Feedback
            BC C/O's
            5mm spacers
            My old Style 5 Thread / My Swap
            1991 318IS :bow: 2.5L S14 Swap/BC Coilover suspension/Some new (old) wheels/
            IS Skirt-Lip/RG Splitter/M-Technic I Spoiler/Dogleg/3.46 Diff/Euro H4 headlights etc.
            1998 528I (Sold) // 2003 540I ///M Sport
              All stock!
                Originally posted by keefy6 View Post
                E46t
                  Raceland coilovers
                  Spring Rate:
                  Front – 375
                  Rear – 295
                  (HATE the spring rate, any ideas where i could get stiffer, maybe shorter, springs?)
                  i can still go lower in the front but i have to cut the original spring perch off. the back im going to take the adjusters out to be a bit lower too.
                  tell me what you think!
                  - S50 Swapped E30 1/1 Mineral White -
                  @vaughnbannister on IG
                    I think you're the first to debut racelands e30 stuff.
                    1991 325iS turbo
                      they actually are not even bad, well except for their spring rates.... hahah i need stiffer springs! D:
                        I wonder why they choose to run a stiffer front rate than back , like 90 percent of e30 setups I've seen run a allot stiffer rear spring than front spring
                        88 325is Five Speed
                        Lachssilber
                          not sure but it actually sucks. like the height is good but its way to soft, do you know where i could get stiffer ones that would fit...?
                            Do you know what size springs they used, you can get new springs from hypercoil, (eibach though ground control) and swift all make good springs
                            88 325is Five Speed
                            Lachssilber
                              they are progressive springs, if that helps?
                                Ill throw my car up
                                Cut stock suspension no camber adjustment
                                Xxr 002 15x9 0 offset 195/50 tire
                                Slight roll on fenders
                                Actually doesn't ride that bad, a little bouncy on fast harsh bumps. I've definitely rode in worse
                                It's my daily driver I'm happy with it
                                Current car-86 325e never ending project
                                You only get out as much as you put into it
