Koni SA short rear shock
    Pelican list a short rear sport shock. What is the benefit to this shock over the standard length shock?
    Link: https://www.pelicanparts.com/catalog..._pg2.htm#item6
    If you’re lowered, you get some extra travel.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
      IIRC the E30 specific rear Koni SA's are all the "compress to adjust" style, but you can get top adjustable Mustang shocks that are valved more aggressively, but only fit aftermarket rear shock mounts (12mm dia hole iirc, +2mm from whatever stock is.).
      Mustang shock Part numbers 8041-1186SPORT or 8041-1026SPORT. Same valving between these two, but -1186 has 50mm of bump stop at end of travel, whereas the -1026 is 5mm shorter overall and does not have a built in bump stop.
      Originally posted by priapism
      Originally posted by shameson
        I loved my Mustang Konis on the Aluminum Monster... jury's still out on the E30-spec SAs... I need to adjust them still and was a bit surprised when I saw what that required
        Simon
        Current Cars:
        -1986 BMW 325e & 1968 Datsun Roadster 2000
        Previous Car Count : 21 ... and climbing...
        Originally posted by Melon
        Let it be known to all. Simon fucking keeps it real.
          +1 for the mustang konis
            If you are lowered with spring rates between 400lbs - 900lbs and want to stick with Koni SA dampers I would go with the custom Ground Control rear damper. Part number 8041-1289SPGC. Use this along with their rear bump stop and you are set.
            These have the top adjustment for rebound and don't require getting under the car and removing the damper to adjust.
            1990 M3
              Can you actually buy these by themselves? Searching that part number on google comes up with very few results
              2003 Z4 3.0 6-speed- Silver, 19's, daily driver
              1990 Silver 325i- Lowered on H&R OE Sports, e90 drop hats, KYB shocks, color matched rocker panels, 16" Emortal RS wheels on 205/50/16 tires... Currently getting a full refresh including an S52 swap!
              1997 Black Ford Probe GT- Stripped to 2220lbs, MS3X, Forged motor in midst of assembly... Dyno results and 1/4 mile times pending
                When I attempted to buy some, they refused. 8041-1026SPORT is working nicely for me in the rear with 650lb springs.
                Front I have 8610-1437 Race in shortened housings, spacer underneath, with 450lb springs. (Although Roysneon runs the same front setup with iX konis and it feels great also)
