Small project - E30 M3 springs refurbished
    Not a big deal, but picked up some E30 M3 springs, 80k miles and just some surface rust.
    Time to get to work with the Dremel and lots of sandpaper and some white vinegar to really get in there...
    Primed
    Then painted. Used VHT epoxy satin black, a couple of coats, don’t breathe this stuff and make sure it has time to cure:
    Testors model enamel for the details.
    This is sort of an experiment, we’ll see how it goes when installed.
    Ezekiel 25:17
    Current flame: E30 318iS Alpinweiss II slicktop / LSD - Joanne
    The ex: E92 335i 6MT M-Sport - Betty
    The heavy: 2001 4Runner SR5 Sport (3rd Gen) - Fred
    Be very careful using vinegar on springs. It often causes hydrogen embrittlement.
    "Tires are our fuse" -Matt Juengel
    1986 325e Sedan | M20B27 parts available for sale |
      Alright - so I went against my better logic and installed these over the weekend. This went fine for the rears and driver’s side, but the passenger side went all to shit. Tie rod threads got destroyed in pressing out of the strut (because n00b) and whoever put the top nut on the strut insert must have been a gorilla, because in trying to take it off I managed to strip the hex on the top of the rod. Oh, and after I got it all installed, I couldn’t get torque on the top nut anyway so something else is stripped, nut or rod threads. Can’t tell.
      Well crap.
      So the car is sitting now about 0.5” lower with a gimpy passenger tie rod (not drivable), and since I don’t really trust that something isn’t seriously hosed with the springs (Googling hydrogen embrittlement was all horror show), I have some OE Sports on the way to go with a new outer tie rod end.
      The question now is, do I order one or two B6 strut inserts? The driver’s side is fine, and has about 10k miles on it. Seems a shame to toss just to match a new passengers side insert, but since this was such a shitshow I’m reluctant to do anything that would need me to take it apart a third time.
      Any thoughts?
      Edit: 16k miles, just checked.
      Ezekiel 25:17
        Not sure if you have terminology mixed up, but the tie rods don't have anything to do with ride height?
        john@m20guru.com
        Links:
          I think he pulled the strut assembly to change the springs, and f'd the tie rod thread pressing it off the knuckle.
          I think it’s just a bad sentence. The springs only dropped the car a half inch, the tie rod is f'd, and he is worried about hydrogen embrittlement..........
          Did I get that right?
          Originally posted by codyep3
          I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
          2001 silver/Blk 325 cabby. SOLD
          2002 325xit Sil/blk. SOLD
          2010 F650gs twin
            Yes, this.
            Ultimately I’m trying to stay close to stock but get some of the body roll and 4x4 height out of the car, without having to go coilover or need a skid plate.
            Ezekiel 25:17
              something simple turns into a big fuck up. sheesh
              we've all been there.
              convertible front sway and m3 rear helps massively btw.
                So is the allen key insert fubar'd, or the actual OD threads on the strut insert?
                If it's the allen key, borrow an impact and they come off pretty cleanly.
                Don't sweat replacing one insert after 10k miles, I generally replace them as needed, not necessarily in pairs unless I am following a regimen (easier to know "ok, both were replaced xxx miles or races ago")
                john@m20guru.com
                Links:
                  Thanks. Sucks for sure. Blew a big ass chunk out of the weekend. Learned a ton...about how it can go sideways.
                  14.5mm rear sway is on the way, along with new rubber from Turner. Same order as the new f'n tie rod, springs, and some other odds and ends. From my reading the 318is has a 20mm front from stock so will stick with that and adjust accordingly. May go bigger on sways but will make that call later.
                  Allen key insert is definitely fubar, which I could have lived with for the time being if I would have been able to get the nut to torque down. However, once I got the nut down to the bottom, it just kind of spun and felt very...not engaging. Leading me to think either the nut or the threads or both are hosed too. Or, third possibility, did I actually end up off the threads at the bottom?? No idea if that's even possible.
                  Fortunately I have an impact that can take it off. And since I'm not concerned about preserving this insert I don't have any concerns about getting some big ol' channel locks on the insert to hold it in place.
                  Good to know it's not a big deal to keep the good strut insert. That definitely helps.
                    Curious as to how this works out.
                    I just received some used M3 springs for my 88 325 iS. Hoping for a bit of a drop and thinking of getting Bilstein B 6's to match.
                    Anyone done this kind of swap?
                      My car is a 318is, so lighter than the 325is (and maybe a little lighter than an M3?).
                      Ezekiel 25:17
                        Right, probably a lot of factors like the weight of the M3 at the front/rear compared to the 325 iS...I'm hoping the strut towers are usable. The rears would be easy to try for size. Perhaps someone has done this to their 325 iS
                        Found this...from an owners manual apparently
                        325i - kerb weight: 1209kg, distribution: F 52.4% / R 47.6% (Battery moved to trunk)
                        318iS - kerb weight: 1132kg, distribution: F 53.3% / R 46.7%
                        320iS - kerb weight: 1218kg, distribution: F 52.1% / R 47.9%
                        M3 - kerb weight: 1237kg, distribution: F 52.2% / 47.8%
                          Ahhh, back to the good ol' days of trial and error.
                          @IRON-E30 aka Edwin:D
                            Ha! I have a good number of parts otw. So many tracking numbers!
                            Ezekiel 25:17
                              Just for fun and future reference, here are the before and after pics of the ride height. Showing about 0.5” drop from stock all around.
                              Stock, front:
                              Stock, rear:
                              M3, front:
                              M3, rear:
                              From a bit of a distance, riding stock 14” weaves. Please forgive the dirty E30 shots, she needs a f’n bath:
                              Excited to see what it’ll look like when I get the Euroweaves and OE Sports on there!
                              Ezekiel 25:17
