Table of Various Shock and Strut Options
    Thought I would post this up here in case it helps anyone out in the future. I tried to compile as much info as I could get on some of the various strut and shock options discussed here and elsewhere. The info is not complete but it is at least a start.
    Front/Rear Application Adjustment Brand Part Number Min Length (mm) Max Length (mm) Body Length (mm) Stroke (mm) Body Diameter (mm) Compression (N) Rebound (N) Test Speed (m/s)
    Front 1995 MR2 Top KYB AGX 765015 356 517 161 55 1422 686 0.33
    Front All e30 none Bilstein HD B6 34-001363 530 618
    Front All e30 none Bilstein Sport B8 34-003350 515 598
    Front 1995 MR2 Rear Top KYB AGX 765016 379 552 173 55 2354 882 0.33
    Front All e30 none KYB Excel G 364021 441 624 183 56 784 294 0.33
    Front 318i, 324td top Koni Yellow 8641 1021sport 485 614 432 129 46 500 750 0.33
    Front 318iS, 325iS, M3 top Koni Yellow 8641 1210sport 488 585 432 97 46 700 750 0.33
    Front 325i top Koni Yellow 86 2277sport 493 610 431 117 46 700 750 0.33
    Rear 82-02 Camaro external KYB AGX 743019 308 513 205 930 300 0.33
    Rear 318iS, 325iS compress Koni Yellow 80 2641sport 341 520 179 600 900 0.33
    Rear 325i, M3 compress Koni Yellow 08 2522sp1 342 510 168 600 950 0.33
    Rear 318i, 324td compress Koni Yellow 80 2522sport 343 549 206 600 950 0.33
    Rear All e30 none Bilstein HD B6 24-020282 333 551
    Rear All e30 none Bilstein Sport B8 24-020275 334 533
    I wanted to add some of the findings I was able to get from Koni. This might help anyone who is doing their own swap with fitting some of the different struts or comparing damping numbers for the ones I listed. These are all for the front.
    8641 1021Sport (E30 325i)
    Tested at .33m/sec
    Compresion –500N
    Rebound –870N (rebound doubles at full firm setting)
    Tested at .13m/sec
    Compression –320N
    Rebound –550N (rebound doubles at full firm setting)
    MinL – 485mm
    MaxL – 641mm
    BodyL – 432mm
    Body OD – 45.5mm
    8641 1144Sport (E30 325iX)
    Tested at .33m/sec
    Compresion –500N
    Rebound –600N (rebound doubles at full firm setting)
    Tested at .13m/sec
    Compression –320N ​
    Rebound –300N (rebound doubles at full firm setting)
    MinL – 411mm
    MaxL – 516mm
    BodyL –349mm
    Body OD – 45.5mm
    8641 1221Sport (MR2 Rear)
    Tested at .33m/sec
    Compresion –500N
    Rebound –1470N (rebound doubles at full firm setting)
    Tested at .13m/sec
    Compression –320N
    Rebound –700N (rebound doubles at full firm setting)
    MinL – 413mm
    MaxL – 580mm
    BodyL – 362mm
    Body OD – 43.5
    8641 1198Sport (G60 Corrado)
    Tested at .33m/sec
    Compresion –700N
    Rebound –950N (rebound doubles at full firm setting)
    Tested at .13m/sec
    Compression –500N
    Rebound –560N (rebound doubles at full firm setting)
