Originally posted by Mystikal
View Post
This is a sticky topic.
Originally posted by Mystikal View PostWe speak offset. Shoot me the available sizes.
16"X8" 15 OFFSET.
THEY ARE ESM Cheapos http://losangeles.craigslist.org/sfv...668326414.html
What size tire would you suggest?
will eventually run Vogtland coils.
Originally posted by Mystikal View Post15's won't rub. 16's won't rub with 205/50 tires. Strut clearance is fine but caliper clearance is dictated by spoke shape and not wheel specs. Gotta test fit them if you've never seen them on an E30 before.
Thanks for everything you do btw. I appreciate it.sigpic
I am working on doing a 5-lug swap on the E30. All the parts for the swap are off a 98 M3 and Z3. I'm not used to looking for 5 lug wheels or their offsets. I will be running Ary's DTM flares to cover some gnarly fender rubbage from the PO, but I want to know what to look for.
I will be running GC coilovers on the struts. I'd like to run 9-10" squared wheel setup for as much grip as possible. The power plant if pretty beefy.
Whats a good offset to shoot for, or where will the outsides of my hubs sit now in relation to the 4-lug so I can do some math.
Thanks!sigpic
Instagram @rebellionforge
Originally posted by Danny View Post16X8 et20 Rota slip streams. Lowered on GC coils. Slightly rolled in the rear, barely rolled in the front.
Currently rubbing like a mad man under turning or acceleration with 225/50/16 Nexens. Looking to move to 225/45/16 Dunlop starspec zII. Thoughts?
Originally posted by Sade View PostThat sounds good. I have been told that there 205/40-17 tire fit in the rotation, no any bigger. I've thinking about that spacer. The front 15mm and rear 20mm spacer spacer. Thanks for info
Originally posted by Skunkworks View Post15"X7" 15 OFFSET.
16"X8" 15 OFFSET.
Originally posted by GT BMW E30 View PostI have a set of ESM BBS Reps from my vert. Staggered setup rear-16x9 et20
front- 16x7.5 et20. Will this fit my IX on stock suspension? If so what tires size (with meat) can i wrap these with?
Originally posted by IronFreak View PostI am working on doing a 5-lug swap on the E30. All the parts for the swap are off a 98 M3 and Z3. I'm not used to looking for 5 lug wheels or their offsets. I will be running Ary's DTM flares to cover some gnarly fender rubbage from the PO, but I want to know what to look for.
Thanks!
You're probably looking for +25 to +30 for a 9-10" up front. +35 to +40 rear (ideally).
