Originally posted by Steve Corbett
View Post
This is a sticky topic.
Originally posted by Mike View PostQuick question, I am looking for a similiar stretch, going from 16x9 (215/40/16) to a 16x8. I am leaning towards a 205/45/16 to achieve a similiar look, but reading the specs on tire rack, the overall diameter appears that I will increase the overall diameter by a little bit. Not a terrible thing imo, the 215/40/16 felt a little short anyways. Does the 205 45 seem like a good move?
Originally posted by funcrew View PostThanks! Update: Used 10mm hubcentric spacers, which required slightly re-contouring the bevel at the edge of the hubcentric part of the hub to kill a wobble condition. Anyway, now there's ~5mm clearance between the tire sidewall and the strut. I don't think a 5mm spacer would have done it. Fender clearance not a problem, but I have HR/OE sport springs which are taller than what most guys are running.
15x8 +22 used to be a common size for E30 track wheels, as well as +20 today. You have lots of clearance.
Originally posted by aworthybrother View PostHi Jay,
What size of spacer and tires would you recommend:
16x7.5 et35
1989 vert with M3 springs
I am currently running 15x7.5 et 25 and would like to maintain the same look but with a 16x7.5 rims. Thank you!
I have a set of borbet type h 15x7 et25mm
Just trying to figure out what size hub rings I need.. I know the measurements go from a 64mm cb to a 57.1mm hub but I wanted to figure where I should buy the rings (heard don't go through tire rack or discount tire direct) and if spacers would be needed. Still a bit of a noob when it comes to wheel fitmentsigpic"God made cars to be RWD and standard"
Goal: Not to roll my fenders
Car: 85 eta
Suspension: HR Race and Billy Sports
Desired wheel size: 17"
Question: How wide of wheels can I fit without fender modification? I've seen people stuff 17x8 front and 17x9 rear. I am going for square setup, so maybe 17x8 front and rear? Then leads the question, recommended tire size? And which offset of wheel should i shoot for?
Thanks ahead of time Jay!
Originally posted by Steve Corbett View PostOK, So 15x8's ET40 with 20mm spacers, what is a recommended tire size? Looks a little slim on choices. Not looking to track this one.
