This is a sticky topic.
    Originally posted by mikerob97 View Post
    Suspension:
    H&R Sport Springs (for Cabrio) Average lowering of 1.4"F, 0.75"R
    Rim Info:
    Konig Rewind
    Diameter 15.0”
    Width 7.0”
    Offset 20mm
    Tire Size Options
    1. 205/60 - 15 (seem to be more avail in this size)
    2. 205/55 - 15 (not many avail in this size)
    Not looking for a track car - but a sporty daily driver. Will the 205/60s fit? Recommendations for tires? Are there other options I should consider?
    Thanks in advance for your dedication to this thread.
    Yes, they will just fit. If your front fender liners are loose (or you get offset front control arm bushings) you might scrub them a bit at full lock but nothing serious. 195/60 and 195/55 both work fine also.
      Originally posted by 18rabbit View Post
      So I have a set of tires that I want to put on my e30 which is lowered on vogtlands and has 16x8 et20 rota slipstreams. The tires are 205/55/16 (and free!). I've been reading yes and no for this fitment. Anyone with experience? Thanks bros.
      Won't fit properly in front. 205/50, 205/45, 215/45, 225/45.
        Originally posted by steve68 View Post
        thanks never went with the wheels, down sized to a 16x8 et25, now looking for tires, thinking 215/40/ or ? have to check the tires sites, thanks for the help,
        205/50, 205/45, 215/45, 225/45. 3-5mm front spacers.
          Originally posted by Mystikal View Post
          17x8.5 +30 is ideal for the rear. 245/40s will work with a roll and stiff enough suspension.
          Ended up going staggered.
          17x8 +20f - 235/40/17
          17x9 +25r - 245/40/17
          I'll throw a pic up on the other page for you one they are all set up!
          BTW: here is the difference between a 225/235/245/245a6
          1989 325is - S52 Turbo Swap
          1995 M3 - SCCA CStock AutoX Car
          1991 318is - M20 swap - 5spd(SOLD)
            I have a 91 318is M50. That has no name lowering springs on it. Dropped like 1.5 inches. I want to put 18x8 4x100 with a 42 offset. What spacers and tires would I have to run for it to fit.
            Current
            99 328i (Sold)
            91 318is M50B25TU
            89 325ix (Parted out)
            87 325is (Parted out)
            95 525i (Parted Motor for 91 318is)
              Shame, those would be ideal about 5mm in. Unless you're running at least -3 front camber the fronts will catch. The rear will rub like crazy but I guess if you massage the fender out enough they could work.
                20mm spacers, 215/35 tires.
                  Yeah I thought about seeing if I could mill the 3-5mm off the wheels to pull them in a little. I put the car back down and bumped the suspension up and down and I didn't hear it rubbing so far. I massaged the fenders "a bit" and got the hoosiers to clear so I think the toyos should easily fit.
                  I also thought about the camber up front, luckily i have coils with camber plates up front, and i know from autoX that the car loves a ton of camber up front for turning. I had 16x8 +20 with 225/45/16 tires on and they fit pretty well with next to no big camber. Granted these are a little bigger with a 235/40 but hopefully i dont have to run -4* up front lol.
                    I have a chance to pick up some 15x7 et25 wheels with 205/50 tires, how close to sitting would i be? its an early car with no fenderwork
                    thanks
                      -3 should be more than enough, and yeah if you're going for function you need that sort of alignment anyway. I daily my car between -3 and -4 depending on wheel setup!
                        thanks
                        Fit perfect without spacers, lots of space inside and out.
                          Thanks! Pretty excited now
                            tires
                            m50 swap 318i.
                            I have a set of KA motors ultra wide flares.
                            Fortune 500 coilovers. Rear isnt a true coilover setup.
                            Firstly is it possible? Secondly, what offset?
                            A 17x9.5 wheel with a 275/40/17 up front.
                            A 17x11 wheel with a 315/35/17 wheel up the back.
                            Thanks,
                            J
                              What is the largest tire I can use on a 16x9 wheel with et12 for offset?
                              I currently have 205/45 and I'd like to fit something wider for more traction. The car is aligned at -3 degrees on all four wheels.
                              I'm thinking 215/45 would be the largest without getting a different wheel.
                                E30m3 body & BBS LM's
                                Want to run:
                                18 x 9" FR
                                18 x 10" RR
                                Is ET15 the right offset all 4 corners?
                                If needed, I have Sport Evo fenders for any issues in front, and am doing 18" because 17" LM's are rare as heck. So deposit is already in on the 18's, just need to know offset - I know alot of East Coast guys run these, just don't know offset.
                                Experts?
                                It's not how you handle the good times, but the faith you keep in the bad that defines you.
