Originally posted by Js2010
View Post
This is a sticky topic.
Originally posted by Grackle View PostHate to ask again, but 16x8's with a +15mm but a 5.09 backspace. Still good to go?
Originally posted by Mystikal View PostDepends on the thickness of the hub of the wheels you're using, which is a figure no specs will give you unfortunately. But with maybe 80% of wheels, yes, for 5mm spacers you will need longer bolts to retain proper threading.
Sent from my Nexus 4 using Tapatalk
Originally posted by Js2010 View PostThanks I am thinking about putting borbet A on the car. So do you still think I will need longer bolts? Is there a risk the bolts I buy might be too long?
There is a chance of the bolts being too long, yes. Stock shank length is around 24mm. Buy bolts with a 28-32mm shank length and you will be good to go.
Car: 1987 E30 convertible
Suspension: JOM (I know) coilovers
Wheels purchased: 16 x 8 et 20 F
16 x 9 et 15 R
Fenders: stock (not rolled/pulled)
Tires: ?
Front: I've read a years worth of this thread and think you're going to tell me 205/45/16.
Rears: I believe you also say I can go 205/45 here too but that's a bit too stretched for my taste.
Can I run 215/45 without modifying fenders in the rear? What about 225/40?
Thanks in advance.Early Model Front License Plate Filler for Sale: http://www.r3vlimited.com/board/showthread.php?t=363721
Late Model Front License Filler Plate for Sale: http://www.r3vlimited.com/board/showthread.php?t=365118
16 x 9 et 15 R
Tires: ?
Thanks in advance.
Originally posted by ginger1340 View PostI have a 1984 325e. Stock suspension
How wide can I go for the wheels I want without rubbing or rolling my fender? I found some 15x8.5 that like but some people say that I would have to roll my fenders
Originally posted by darvo View PostE36M fitment on front, e30m on back. Late model. 17x9 et35 front or 17x8.5 et30? What tire option do i have for these? Rear will be 17x9 et22, Ge Coils cut perches
Originally posted by mbonanni View Post1988 325ic
17x8 et2 front
17x9 et6 rear
Can this be ran with 205/40 front and 215/45 or 215/40 rear, with a roll and pull? Will be lowered on coils, but not super low.
Same car
16x8 et5 front
16x6 et3 rear
Can 205/50 work on these with a similar roll and pull for the set above?
