Touring suspension question
    Nice,
    Somebody told me I should get the b8s though
    RESTART
      I run 6” 1200lb swift springs in the rear with stock bilstein shocks. Drove it like that from Phoenix to Fontana, California no problem still very comfortable.
        Originally posted by restart View Post
        Nice,
        Bilstein Tourings will be softer, sports/B8/HDs more firm. Since a touring is not a race car I'd go with OE sport springs, maybe verts in the back and Tourings or Sachs Advantage if you can still find them.
        New OE springs are also an option, especially if you haul cargo.
          From the bilstein site It looks like the b8s use the same part number
          As all the other e30s.
          They list 51mm for fonts
          But all the rear shocks say 45mm
          Does that sound correct.
          Front>>>
          Bilstein BMW 3 Series (E30) Touring 325 i B8 Sprint Shock Absorber
          Bilstein number: 34-003350
          Type: Bilstein B8
          Scope of delivery: Patroon demper
          Side: Front
          Type Shock Absorber: Mono-Tube Upside Down
          Engine power (KW): 55 - 141
          Comments:
          with sports suspension VA: outside diameter strut 51 mm HA: charakteristic: 160/55
          Rear>>>
          Bilstein BMW 3 Series (E30) Touring 325 i Rear B8 Sprint Shock Absorber
          Bilstein number: 24-020275
          Type: Bilstein B8
          Scope of delivery: Shock Absorber
          Side: Rearzijde
          Type Shock Absorber: Mono-Tube Gasdruk
          Comments:
          with standard chassis VA: outside diameter strut 45 mm HA: charakteristic: 160/55
          Link to e30 bilstein reference>>>
          http://www.bilstein-shop.com/bmw/bmw...c-1_61_70.html
          There are button s at the top of page to filter b8 or b4s etc...
          RESTART
            Looking around in Europe where tourings are commonplace.... I see different shocks for the touring vs cabrio.
            While we are talking suspension here are e30 vs cabrio vs touring weight/distribution for reference...
            I hope pics show up inthread if they donít can someone post them some external link is not required.
            RESTART
              I dunno why pics show up sometimes and sometimes not.
              I think I have decided to go h&r lowering with bilsteins ordered from Europe at a shop that has a separate spring for touring...
              RESTART
                These..
                Shocks
                https://www.ebay.ca/itm/BILSTEIN-B8-....c100167.m2940
                And Springs
                https://www.ebay.ca/itm/H-R-lowering...72.m2749.l2649
                Yeah I typed all that:-)
                RESTART
                  I ended up pulling the Billy sport kit off the Rat Trap ('87 Sedan I parted out) and throwing it on my touring. You do lose a little stiffness in the rear, but unless you're towing, you probably won't miss it.
                  1984 Alpina B6 2.8/1 #35
                  1991 Racecar (Chase Schmidt's former drift car - M30)
                  2006 BMW X3
                    getting back into my suspension here and time to upgrade the shocks to match the springs. looking for proper street dampening and comfort to support my slightly lowered height.
                    sounds like a lot of guys went Bilstein B8 here, touring specific when possible.
                    im on H&R Touring springs + B4's now. has anyone gone B6 or is that only if your car is not lowered?
                    any experience with a slightly lowered Touring on B6 vs B8 would be appreciated.
                    thanks
                    '89 E30 Touring, '85 911 3.2 Coupe, '89 GB500, '96 XR400
                      The shxocks I used (above) are stiff. Handles nice and where I live roads are smooth.
                      If roads were bad I would go softer suspension.
                      RESTART
                        right ok - and if the car feels overall a little rickety still after that would you move to bushings or ? and i mean just new oem bushings, not going poly. sometimes the touring feels not as "solid" but could also be from all the interior panels noise in the wagon that i need to get tight?
                        thanks
                          I hope pics show up inthread if they don’t can someone post them some external link is not required.
                          Great info! Using your attachments, here are the F/R weights.
                          1396/1269 Sedan
                          1447/1320 Cab
                          1428/1372 Touring
                          So the difference in front weight from the sedan is 33 lbs for the touring and 51 lbs for the cabrio. The rear difference is 103 for the touring and 51 for the cabrio.
                          Per the H&R site they only make the "OE Sport" springs for the sedan/coupe. Has anyone tried these springs on a cabrio or touring?
                          Cory
                          1992 325i 'vert
                          1988 320i Touring
                          1977 530i
                          2015 328i - Euro Delivery/Performance Center Delivery
                          2001 325i - R.I.P.
                          BMWCCA
                          E30CCA
                            1396/1269 Sedan
                            1447/1320 Cab
                            1428/1372 Touring
                            Cory
                            The weight distribution doesn't tell the whole picture. The touring has a significantly larger percentage of its rear weight behind the rear axle. Quite a bit more than the sedan or cabrio do.
                            I can tell you from my experience, that 475lb rear springs were no where near adequate to keep the rear end from bouncing around like crazy. This was a Ground Control coilover setup, and at full ride height, I would still bottom out with people in the back seat.
                            It took 700 lb rear springs to make the back end feel nice and tight.
                              AFAIK h and r e30 touring 30 mm drop number is 29684-1
                              That’s for the 6 cylinder...
                              The 4 cyl touring has different springs which you might consider in your comparison.
                              I dont know if h&r USA has listings for touring but They might find it with the part number
                              Here is a link for e30 325 touring at h+r
                              https://www.hrsuspension.direct/page...?product=75074
                              RESTART
                                Thanks for the great info. I'm a noob to aftermarket suspensions. My goal is to lower the car a little bit but still use B4 shocks. That's why the H&R OE Sports seemed interesting.
                                Cory
                                1992 325i 'vert
                                1988 320i Touring
                                1977 530i
                                2001 325i - R.I.P.
                                BMWCCA
                                E30CCA
