Koni’s - Which ones do you use on a Touring?
  • mach schnell
    • Apr 2008
    • 1059
    Looking to get a set of Koni’s for my rear wheel drive 325i Touring.
    Which are the correct ones? I’m going to run them with a set of H&R Sport’s that are Touring-specific.
  • roguetoaster
    Biggus Tippus
    • 7830
    Have a look here https://www.koniuk.co.uk/vehicle-search-form and pick the part number you feel will be best. Alternately, call or email Koni.
    Keep in mind that many of the P/Ns will be the same as off the shelf dampers aren't really matched to non-stock springs. You can also try to look up spring rates and see if the H&R sports you have are pretty close to any stock springs so you can get closer to having a factory type sport suspension.
    • mach schnell
      • Apr 2008
      • 1059
      Good call, thanks. Is there any point in getting top-adjustable shocks for the rear? On a normal E30 it’s easy to adjust the tops through the trunk, but the Touring has all the interior trim etc.
      • roguetoaster
        Biggus Tippus
        • 7830
        Nah, alao with adjustables most seems to set them, maybe change them once more and never touch them again. IMO, a waste.
        • mach schnell
          • Apr 2008
          • 1059
          Yeah. Makes sense. I guess the M3 versions are shorter. So that’s useful for a lowered car. Hmmmm.
