Transmission Transfusion Troubles
    Hi guys,
    when you swap out an engine and transmission together as one piece and the angle is getting close to 90 degrees upright...If you don't drain it, does all the gunk at the bottom on the trans swamp get into the solenoids and other electronics of the transmission? I know that the filter would prevent it during the course of normal use but under the extreme angles involved, could this muck up an otherwise good-working transmission?
    Thanks
