Quotes from OP: I can do some of my own mechanical work (have pulled engines/trans and swapped suspensions) but don’t have a ton of time and don’t do well with electronics/computers so in general prefer OEM like kits/simplicity. Willing to spend some money to get there
Was looking to spend 10-15k to get a nice car with clean body and interior (I dislike body/interior work) and then limit a swap to $10k total (parts and labor, labor divided between myself and a shop depending on level of difficulty)
Unless I missed it have you mentioned test driving ? 25K budget. Money gets spent quickly on swaps. You should go drive 3 types of e30's that are most available and make a decision after that. The 318is will highlight handling over power and end the debate over what version of engine is best for canyon carving. Kits are available and K-power will even do your swap. The 325is m20 or an M20 stroker with suspension mods would help you in terms most easy to modify and may be enough for you. S50 swapped e30. more power and a longer engine but again a OEM type kit. If you prefer the 24 valve set up its time to get a shop quote you the N52 cost for the work your not gonna do. what every you do get a build going on the project forums and document it. There is still lots of enthusiasm for the e30.
