1990 325i Airbag steering wheel swap for M Tech 1 wheel?
    Thinking about swapping my M Tech 1 wheel into my 90 325i. Any problems with airbag lights? .... or other issues I want to know about?
    Thanks
    sigpic 1987 325is
    You'll need another washer to throw in there for it to fit snug.
    1991 325iS turbo
      I went by this post: http://www.r3vlimited.com/board/show...55&postcount=3 when I did mine, don't forget to remove that little white pin, or your steering will lock-up while trying to turn the wheel.
        Hi, Just swapped my airbag steering wheel to M1 BMW steering wheel, can anyone help me out regarding connecting the horn on the M1 steering wheel ??? I drive a 1991 318..Thank You in advance..
          If you do it right, everything should work. Make sure everything is done right...Wheel/spacers/nut. Remove spring loaded peg, disconnector airbag connector under the dash at the orange box. Enjoy.
          88 M3 - LACHSSILBER/SCHWARZE
            You wont have any issue, follow what others have said. I removed mine, I went a step further, I removed the whole airbag computer (orange box) and I also swapped my overhead check panel for a non airbag version so the light was not even there. You can also just pull the bulb if you want.
            Before
            After
              Originally posted by Staszek View Post
              You wont have any issue, follow what others have said. I removed mine, I went a step further, I removed the whole airbag computer (orange box) and I also swapped my overhead check panel for a non airbag version so the light was not even there. You can also just pull the bulb if you want.]
              Do all the other functions on the non-airbag overhead check panel work?
              Thanks, Cory
              1992 325i Cabrio
              1988 320i Touring
              2000 M5
              1977 530i
              2015 328i - Euro Delivery/Performance Center Delivery
              BMWCCA
              E30CCA
                Thanks, Cory
                Well they did until I swapped to the S54. My seatbelt, and brake check still work now. If all you are doing is the airbag, all the rest should work fine.
                  Interior looks great! Loove the doors!
                  I don't know why I never thought to get a non-airbag check panel. Thank you!
                  20% Accurate
                  Morty: Well Summer maybe people that create things aren’t concerned with your delicate sensibilities you know? Maybe the species that communicate with each other through a filter of your comfort are less evolved that the ones that just communicate? Maybe your problems are your own to deal with and maybe the public giving a shit about your feelings is a one way ticket to extinction.
                    Thanks!
                    They are pretty cheep online I think I got mine for $30.
                      Before
                      After
                      did you bend your indicator stalks back at all? curious if the wheel sits really close or not? Thanks
                      1991 318is
                      2004 330ci
                      2011 335d
                        I actually bought preairbag indicator and wiper stalks, you dont have to you can probably bend, but I wanted the right ones.
                          All of the above is correct. I put a 3-spoke in my 1992 cabrio. Now I don’t hate my steering wheel.
                          I kept my airbag steering column turn-signal and wiper stalks. They’re close to the back of the steering wheel, but I don’t mind driving it like that.
                          Word of advice: make sure that the airbag system is completely de-energized and discharged before messing with the airbag steering wheel. Those things can kill if they go off inadvertently.
ID:	9926700 Click image for larger version
                          Jon (OO=[][]=OO)
                          1992 325ic white, stock with a 5-speed swap
                          Palm Beach County
                            Thank you. I currently have the original spacer-wheel-spacer and then a washer and still need to get another washer or two for the horn to make contact. Dreading bringing it even closer to dashboard.
                            1991 318is
                            2004 330ci
                            2011 335d
                              So the hub adapters that say they do not work for a 1991 325i, is this simply because of the airbag? And with the above fixes (spacers,removing white pin,disconnecting the airbag computer) the hub adapters will work otherwise? I know signals and wipers will be close. Thanks, trying to do all the searching I can myself but a lot I threads end without answers.
