A couple inline six questions
  • Fusion
    • Nov 2009
    • 3659
    I'm looking for a motor for an out-of-car project and it has to have these requirements:
    - inline six
    - single overhead cam
    - aluminium block
    - can be diesel or gas
    I chose I6 because they seem the most balanced to me. I know I could look at I4/5s, if all else fails.
    The problem is that BMW started R6 alu blocks with the M52, thus 24V. (I didn't study M engines since price is an issue.) If I remember correctly, Mercedes engines are pretty much the same.
    I think the 4.0 Jeep engine might be what I need. Any others? Not pre-90's though as they would probably be hard to find.
    And I have these really weird questions:
    If I did get the M52, in theory - I know this wouldn't run, would an M20/30 cam have the correct spacing between cylinders (top view) and could timing be tweaked to the correct unity with the crank? Ie. to set Cyl1 to TDC, cam intake 1 pointing down, set chain, keep this timing even after many turns of the setup.
    And a physics question - what is the approx. combustion pushing power on the piston in lbs/kg in these engines?
  • gearheadE30
    • Jun 2007
    • 3734
    Well, what is the engine going to be used for? Aluminum block SOHC I6's are going to be a little hard to come by... And M52 blocks are nowhere near the same as M20's, plus the timing system is completely different. After all of teh fabrication and design work, it would be cheaper to do just about anything else.
    I'd look into motorcycle engines personally. You'll be looking at an I4, but they are extremely powerful and compact and are also pretty easy to find because of all the people who wreck bikes, heh....
    Project M42 Turbo
    • Fusion
      • Nov 2009
      • 3659
      I'll look into them. My knowledge of motorcycle engines is zero but I'll see what I can find.
      • tjts1
        • May 2007
        • 1851
        B6304. You'll find it in any JY. Its DOHC and dirt cheap.
        • Fusion
          • Nov 2009
          • 3659
          I need SOHC, but I'll look at wat else Volvo made...
          It's pretty much an art project where we want to show the cam-crank-piston movement. So I don't need a head (so you can see the pistons move) and I could also make a home-made cam, I was just thinking it would be easier to use an old cam because it has the gear etc. Maybe I could take just the intake cam and move it to the center, ditch the exh. cam and go from there.
          • tjts1
            • May 2007
            • 1851
            There is a 10 valve DOHC volvo inline 5 white block volvo but as far as I know alloy block and DOHC went hand in hand. Most Porsche 944s got an 8 valve SOHC alloy block engine.
            • Fusion
              • Nov 2009
              • 3659
              I still haven't figured this out, not even google knows. This is at idle btw.
              And would anyone take a wild guess at what the crank power output might be at idle, no accessories, on let's say a ~200hp M52?
              • SpecM
                • Oct 2005
                • 4531
                why don't you tell us what you're doing with this engine?
                1989 cirrisblau-metallic 325i
                • payney8
                  • Jun 2007
                  • 899
                  • Fusion
                    • Nov 2009
                    • 3659
                    Yea, I don't really have an explantion for it.
                    If I were building a BMW tractor, I would've written it right away. This is just a project in the brainstorming phase.
                    • e30lov
                      • Jul 2008
                      • 1597
                      jeep 4.0L
                      `92 325 vert - `90 325 coupe `99 m3 - Instagram @e30L
                      • tjts1
                        • May 2007
                        • 1851
                        Originally posted by e30lov
                        jeep 4.0L
                        Oh yeah! Thats totally alloy block and OHC
                        Hey I know. Cummins 6BT
                        • gearheadE30
                          • Jun 2007
                          • 3734
                          Out of curiosity, why does it have to be an aluminum block?
                          And the jeep 4.0 is SOHC. Good luck finding an I6 that is pushrod (OHC).
                          Project M42 Turbo
                          • e30e
                            • Dec 2004
                            • 2176
                            GM makes pushrod inline sixes, they have for hundred years now.
                            As of the for the OP, nothing what your asking for really exists in the mainstream.
                            1985 BMW 325e
                            1997 BMW M3/4/5
                            2007 Chevy Silverado Crew Cab 5.3 v8
                            • Conki
                              • 1254
                              You mean OHV.
                              1992 BMW 525iT Calypso
                              2011 Jeep Wrangler
