POST YOUR THREAD IN THE CORRECT FORUM
The General Discussion forum is NOT a catch-all.
Please post your topic in the correct subforum.
Technical questions do not belong in General Discussion, neither do body kit or wheel fitment questions. If you don't know where to ask your question, post it in General Technical and we'll move it to the appropriate subforum if necessary.
This helps keep R3VLimited nice and organized so others can more easily find what they are looking for.
Thank you,
R3V Staff
See more
See less
Honda K24 swap interest?
    Originally posted by The Dark Side of Will View Post
    Why not the K-series? No properly configured catalyst because it's FWD only?
    Bingo. As far as I can tell F20c headers have to cats so we can use whatever we want for our swap in California. RWD intake and Honda transmission helps alot aswell.
    91' 318is 90' 325is
    Originally posted by Sonny
    Buy the E30s, they ain't gonna last long
    E30 can make you, E30 can break you
    "He who controls the Nova's, controls the Boomers"
      Very useful document for BAR legalization in California.
      I found this pertaining to using a OBD2 motor in a non OBD2 chassis (K swap)
      The donor engine must be in a stock certified configuration, and support all the certified OBD-II functionality
      ē Modifications of the intake and exhaust system are permissible only if necessary to accommodate the packaging of the vehicle and only if they do not affect the functionality of the systems
      ē The transmission and evaporative systems will be allowed to remain in the recipient vehicle configuration, but must function appropriately
      Page 5 on this PDF from the PDF
      https://www.bar.ca.gov/pdf/Engine_Ch...G_04.19.18.pdf
      Reading this aftermarket intake seem ok as long as you don't delete any emission devices. Perhaps custom Exhaust manifolds with welded on cats would pass too.
      91' 318is 90' 325is
        You can use a stock s2000 intake manifold with a JSP adapter.
        https://jspfab.com/products/jsp-k-se...ntake-manifold
        Modifications doesn't necessarily mean after market. You would most likely be better off using an actual Honda intake manifold.
          Or probably an aftermarket one that has gone through the CARB cert process and has the ever important sticker to prove it.
          OBDI M62B44/6 swap
          Transaction feedback
          - jpod999
            None available. Sent from my iPhone using Tapatalk
              Dont take my word for any of this cali legalization stuff.
              Below are the oem manifold for a TSX its good news because there is no catalytic converter built in, they are in the actual exhaust pipes.
              18100RBB010
              04-08 TSX-Exhaust Manifold
              The way I think BAR laws work is you can modify pretty much anything along as you retain all the factory emissions equipment in there positions. this is why you can BAR a M50 swap but not a M54 swap in California.
              M50
              M54/M52
              So for Honda swaps The F20 should work with its RWD exhaust and intake.
              For the K series perhaps mounting F20 headers ( oem honda parts)
              ex:
              https://www.facebook.com/BYPRacing/p...32966213422110
              ex:
              https://www.balladesports.com/produc...anifold-header
              91' 318is 90' 325is
                Fwd version wouldnít work? Donít mind me, I donít know anything about these motors.
                OBDI M62B44/6 swap
                - jpod999
                  Fwd manifold puts the throttle body pointing towards the firewall. Sent from my iPhone using Tapatalk
                    any real updates on this? while California smog stuff is interesting and I've learned a lot since it doesn't apply to me I could care less lol Sent from my iPhone using Tapatalk
                      Same. Starting to source parts for my swap. K24a8 and s2k 6 spd so far. My intention is to give it some boost. :)
                        Any word on K24W with direct injection?
                        The factory turbo K's of the last couple of years are closing in on 300 HP.
                        Reasonably informative articles on K-series variants:
                        http://mywikimotors.com/honda-k20a-k20c/
                        http://mywikimotors.com/honda-k24a-k24z/
                          This question is of topic but is anyone else having the same problem as me I canít see any photos posted in the forum? Sent from my iPhone using Tapatalk
                            And does anyone have any supercharger ideas ? Sent from my iPhone using Tapatalk
                              Any word on K24W with direct injection? The factory turbo K's of the last couple of years are closing in on 300 HP. Reasonably informative articles on K-series variants: http://mywikimotors.com/honda-k20a-k20c/ http://mywikimotors.com/honda-k24a-k24z/
                              The ilx motors look interesting; intake and exhaust are flipped and the motor itself is more efficient Nobody has swapped one of the direct injection k motors into a Honda yet; as soon as that happens it should be figured out. Only Cali-bar legal ok Honda swap for a e30 will be a complete f20c/f22c. Simply because the manifolds work for rwd Realistically this isnít a bad situation at all because the f20c/22c just rips, s2000 gearbox bolts to it and is awesome.
                                Originally posted by Shangsta View Post
                                Any chance you will be bringing either of the cars to e30 Octoberfest?
                                No, we just don't have time. Maybe next year
                                1993 BMW 850ci factory 6 speed
                                1992 Honda Civic Hatch, built B16, turbo, and nitrous
                                1989 BMW 325i, f20c swap
                                1989 Honda CRX, built LS/vtec, turbo, and nitrous
