so yeah im stupid
  • willsol
    • May 2007
    • 334
    so yeah im stupid
    Ok so I went to tune up the E30 the other day and I didnt bleed the air out of the radiator after changing the fluid... so now I have leak comming from the intake area..around a seal.. anyone have the part number??
    And maybe a leak close to the block... looks like I really fucked this up.
    Anyone in the Virginia area that might be able to help, let me know. I could use it.
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    Very ambiguous. what intake part number are you referring to.... by a hose? the water pump seal?. any pics?
    please tell me you didn't put the orange dex-cool fluid in.. it eats the seals. use only prestone 50/50 (although bmw coolant is preferred, but really no difference).
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
    • willsol
      • May 2007
      • 334
      I used the green stuff and went 50-50.. I just didnt know about the bleeding part. I do now though as I just got my bentley manual in.
      I believe its the seal up around the intake where two hose connect up...and it looks like its a bitch to get off the intake manifold.
        • 37828
        Not bleeding the cooling system has nothing to do with blowing seals.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • Garageaholic
          • Dec 2005
          • 5204
          it seems you might simply have a bad T-stat housing gasket. drain, replace T-stat, seal, and T-stat housing gasket, rebleed and you should be fine.
          your hoses will explode from air in the system well before your seals will fail.
          Recent Rebranding!!
          E30 SM62/S62
          E30 M60 V8
          E30 M30 Big 6!
          • willsol
            • May 2007
            • 334
            one of the hoses exploded too... I apologize for not mentioning that earlier... the hose was the easy part to replace.
            but is there anything else that could of caused the seal to blow cause it was pouring out pretty bad.
            • willsol
              • May 2007
              • 334
              How do you replace the T-stat... the little round bolts looked like a allen wrench went in there but Im not sure and dont want to fuck anything else up on this.
              • NC325iC
                • Mar 2004
                • 6565
                your talking about the coolant housing on the throttle body, ive had those go bad, its just a really thin cork gasket
                • willsol
                  • May 2007
                  • 334
                  I think so right up near the throttle body...
                  • erik325i
                    • Jan 2005
                    • 3567
                    Ohh, if it's that one, I would just bypass it unless you live in a place where it gets really cold. That is the throttle body heater and it is there to prevent the throttle from freezing closed. The little cork gasket leaks, so I just joined the two hoses together to bypass th throttle.
                    -Erik
                    • willsol
                      • May 2007
                      • 334
                      Oh snap... I didnt think of that... I will try to do that tomorrow. It doesnt get that cold here in VA.
                      • Garageaholic
                        • Dec 2005
                        • 5204
                        -Erik
                        why didn't the M30's come with it or the M50's... or any other engine?
                        Recent Rebranding!!
                        E30 SM62/S62
                        E30 M60 V8
                        E30 M30 Big 6!
                        • erik325i
                          • Jan 2005
                          • 3567
                          No clue
                          • kellie
                            • 702
                            Whenever I get an E30 at work that needs cooling system repairs, I recommend replacing every single tiny little piece of the cooling system for this exact reason. It's like a domino effect. You replace one part, then another fails, then another, then another, and before you know it, the car has been back 3 times in a month because every time you replace the weakest link, the next weakest link goes. Ahh!!
                            Anyway, don't feel bad. It isn't necessarily something you did wrong (although you definitely want to make sure you get all of the air out of the cooling system, otherwise you risk overheating), it's just the nature of old cars. I'd definitely replace that little cork gasket on the throttle body, along with the metal plate and the 3 screws.If there are any other hoses that look or feel hard and brittle, replace them while you're at it. I'd try to get all of that stuff out of the way just so you don't have to worry about it anymore. It sucks to have a heater hose burst on the freeway. Just ask Ben Carufel.
                            • e30frosh
                              • Dec 2004
                              • 2170
                              I've been running my car fine without the t-body gasket....not a drip. No air in the cooling sys either. Maybe I'm lucky.
                              Every day I wake up we drink a lot of coffee and watch the CNN
                              Every day I wake up to a bowl of clover honey and let the locusts fly in.
                              Lobsterbacks attack the town again
                              Wrap all my things in aluminum
                              Beams of darkness streak across the sky
                              Pink rays from the ancient satellite
                              Every time I look out my window same three dogs looking back at me.
                              Every time I open my windows cranes fly in to terrorize me.
