from slowwww to gooooo! my first e30 project
    i got this car for free.. it was given to me by my dad's friend....
    it was a beat up m10 that had seem better days..
    the start:
    the interior =] its in good shape
    good bye m10
    new motor =]]]
    new motor in=]
    radiator
    rear strut bar
    finished product... (half ass if only the cons were done with)
    Thats most of the pictures I took.. Most of the time i saw working on it and didn't really have the chance to take pics.
    I installed a z4 short shifter.... i needed an adapter which i got from gregslow318i (great guy.. awesome work)..
    pros: -I've learned a ton for my first time working on a bimmer.
    -the m42 was bored to a 2.0 and cammed, and has the m20 flywheel conversion....
    with dinan chip from TNG's.
    -the car is fasstter than my m10.
    cons: z4 shifter hits the drive shaft:hitler: The only gears it doesnt hit is 2nd and 4th. FIXED!
    the idle goes up to 1000 normally and the goes up and down from 900 to 1200 rpm :hitler:FIXED
    my whole car has the "shakes" i dont know why it does that.... LIVE WITH..=]
    future: ie3's billies or koni yellows, speakers , and the list never ends=]
    my project
    http://r3vlimited.com/board/showthread.php?t=164374
    I do not understand why you swapped to an m42? Why not m50?
    John F. Kennedy
      nice man good luck how is the body??? any cancer?
        Oh my god, TNG's!!!
        Did you buy that motor from Danny?
        Classic BMW Specialists
        Santa Clarita, CA
        www.BimmerHeads.com
          Very nice, cool swap to do! A big improvement over the M10.
          Santa Clarita, CA
          www.BimmerHeads.com
            That's really cool that you stuck with the 4 cylinder.
            Nice work!
            '91 "318is" slick top M50 turbo
            '97 Dodge 3500 12v Cummins
            '12 Mini Cooper S
            '89 318i Chump Car Project
              Ive always wanted to build one of those.
              Trash my shitty 318is shell and put everything in a clean early model
              Good luck with it
              What do you mean my the shakes?
              Hunter
              We're out there in here.
                for the shaking and erradic idle check ure vacuum lines, bet u got a vacuum leak somewhere.
                  What's up neighbor? :) My car does the same thing when I first start the car in the morning before settling down. I've been trying to find the source of the vacuum leak somewhere but so far no luck. Nice project.
                    Sum More improvements That i was lazy to post... tehehe
                    Beeefffoooreeeeeeeeeee
                    Afterrrrrrrrrr
                    BEforee
                    Afterrrr
                    My Timing chain looks cleannn
                    CAMMSS
                    my project
                      CAR PICSSSSS ... with the Bottle Capss,...... sooon to be changed when i gett the funds=]
                      THIS is one of MY FAVORITES at my Friends Shop
                      Bimmer Festt!!!!
                      my project
                        2.0 liter huh!? Sounds badass. Nice work with the swap.
                        -Nick
                        Originally posted by 87e30
                        First of all: calm the fuck down; second of all; cool story bro.
                          wow man, good work. really keeps me going on with my project.
                            Grab a can of carb cleaner and spray over your vacuum lines. When your idle bumps up, inspect where you were spraying...should be pretty close to finding your leak. I had one where a hose was torn underneath a hose clamp, so wiggle and prod around a bit.
                              have you driven an m42 car before?
                              www.instagram.com/dsloanphoto
