My 333i turbo
  • scoobydo
    • Sep 2013
    • 137
    #61
    I got a large folder of history and magazines that featured interesting BMW's and also my car this was collected by the 2 previous owners. Yes the 333i was rated at 194bhp. Mine was turbo'd in the late 80's and then re-worked in the 90's raising it to 450bhp 520lbs of torque so quite a healthy gain. Also got the original owners manual here
    • Old city bimmer
      • Jun 2014
      • 1114
      #62
      that care is sweet..........
      323i MTEC1
      Z3 coupe
      E60 M5
      • Ray Smoodiver
        • Jun 2004
        • 8809
        #63
        I've got a complete part list for the 333i from BMW South Africa if anyone wants me to post it.
        • scoobydo
          • Sep 2013
          • 137
          #64
          IS this the deviated parts list, think 3 a4 pages with the AA (alpina number) and any other standard bmw part that was used not from the E30 range?
          • e30m3s54turbo
            • Jun 2010
            • 3210
            #65
            I would like to see it.
            • scoobydo
              • Sep 2013
              • 137
              #66
              productmanualguide.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, productmanualguide.com has it all. We hope you find what you are searching for!
              Is a copy of what I have.
              • Ray Smoodiver
                • Jun 2004
                • 8809
                #67
                Yep that's the one.
                I've also got the 325iS Evo 1 and Evo 2 ones as part of the same pdf - post it?
                • Alpina
                  • Oct 2004
                  • 838
                  #68
                  These 333 is IMO the greatest non ///M..... E30 ever made
                  204 made and the most powerful E30 that left a BMW factory.. excl M3///
                  i am an ALPINA fan to the highest but ,, this car is so special
                  to me personally i think that value of these cars will go higher through the years,,
                  the only negative about them is RHD,,
                  the LHD market is more potential i think
                  MANY MANY Alpina parts were used .. and the car is so individual, in many ways
                  these dudes in ZA they also made the 745 with M88/3............. MANUAL ((17 cars of 209 made )) and the only EVER to date 7 serie that left the factory with a semi-race ITB engine... i have heard that 6 manual EURO 745 turbo were ordered by special request
                  and the 530 MLE E12,,,,,,,,,,,,,, one of the greatest E12 that BMW ever made
                  yes.. we should salute BMW South-Africa for making some of the greatest and most desire BMW that planet earth have seen
                  Sveinbjörn Hrafnsson
                  E30 CABRIO V12 M70B50 ///
                  ALPINA B10 BITURBO 346 @ 507
                  E34 550 V12 JML
                  Finnish wisdom : If you want to Win,, hire a Finn
                  http://alpina.123.is/pictures/
                  • e30m3s54turbo
                    • Jun 2010
                    • 3210
                    #69
                    Any up dates?
                    • scoobydo
                      • Sep 2013
                      • 137
                      #70
                      Been busy with some house building work recently so had no time. Will try and at least get some scans of the old paperwork I have uploaded. Have got my new engine mounts from 300mm.de to push the engine back further towards the bulkhead to enable a front mount instead of the side mount. Looking possibly at the evo9 intercooler route, have seen others using that.
                      • Alpina
                        • Oct 2004
                        • 838
                        #71
                        like.. on the 300mm.de mounts
                        i think that is a solution you will be pleased with
                        E34 550 V12 JML
                        • scoobydo
                          • Sep 2013
                          • 137
                          #72
                          Update time.
                          Not good news, car went for MOT and passed with no problems, 3 hours later after using the car, the Alpina radiator decided to spring a leak. Didnt overheat only lost about 250ml of coolant. This has now forced my hand in putting the e28 radiator in and changing over to "Tinos" mounts. Not sure whether to tackle myself or give to a garage that is 60 miles away. I have a garage but not double width so working on the car inside is not the easiest. I have some questions on the Alpina sump, and b32 oil pick up. I will need to change the sump to move the engine back enough, however as I understand this requires a new pick up or is it complete pump? Looked on real OEM and they look different beyond the pickup mine I believe has two holes where as the later version are slotted. How would you guys tackle this I am competent with the spanners. Also have the question about the rear pipe that apparently the old M30 have on the head not sure if I still have this or if BMW deleted it, I do have a pipe that comes from the expansion tank going across the bulkhead area is this the pipe they talk about.
                          new style pick up
                          old style additonal item 4 which looks like the slots are in a different plane item 12 and also looks like there is an additional gasket item 15 and only 2 holes on 13
                          However on the brightside I will be one step closer to a front mount which will unleash more ponys
                          • e30m3s54turbo
                            • Jun 2010
                            • 3210
                            #73
                            Oil pump and pan with pick up for position 2 and 3. You can use a e34 m30 535i or e32 m30 735i.
                            • scoobydo
                              • Sep 2013
                              • 137
                              #74
                              can source the pan but was rather hoping that the oil pick up could be bolted to current pump body. If this is not possible then cannot even seem to source a complete pump. Maybe modify the Alpina pan and weld back up?
                              Also looks like the sprocket arrangement is different for the newer pump.
                              • e30m3s54turbo
                                • Jun 2010
                                • 3210
                                #75
                                I would not ruin the Alpina pan. It would be easier buy a used e32 or e34 oil pan. To modify would be to much work and costly. Here are some pics pf both side by side.
                                DSC03868 by m3raul, on Flickr
                                DSC03867 by m3raul, on Flickr
                                DSC03866 by m3raul, on Flickr
                                DSC03865 by m3raul, on Flickr
