Originally posted by rjsimeon
View Post
Andrew's Sterlingsilber 90 325iS -> 318iS
sub'd quality content here! I dig it!FEEDBACK:
http://www.r3vlimited.com/board/showthread.php?t=316212
BMWCCA #398608
IG @yagayo38
"The Best E30's were built with two camshafts four cylinders and sixteen valves!".
I'm starting to gather parts to renew the brakes. I got a pair of rebuilt front ATE calipers. The ones on there now are Girling. I read the ATE ones can use the brass bushings, but I've also read mixed reviews on those so maybe I'll just use the stock bushings. Since I have 15" wheels I've thought about getting a little bigger brakes too. I could get E30 M3 calipers for the rear and run the Z1 rotors, but then the bias might not be ideal without upgrading the fronts. The Z1 had regular E30 brakes on the front, but I'm not sure all the engineering/reasoning for that with the larger rear brakes. So I think I'll just keep the rear brakes stock, especially since regular E30 rotors are easy to come by and inexpensive. I think I might try the cryogenic rotors. I read they are less likely to warp and last longer. I'm a little undecided on the brake pads. I might try the new Centric PQ PRO pads. I haven't read any reviews for them yet though.
Originally posted by ATL_E30 View PostMan those look clean, where did you snag them?
Originally posted by Andrew325is View PostRockAuto2006 GMC Sierra 2500HD 4WD LBZ/Allison
2002 BMW M3 Alpinweiß/Black
1999 323i GTS2 Alpinweiß
1995 M3 Dakargelb/Black - S50B32/S6S420G/3.91
1990 325is Brilliantrot/Tan
1989 M3 Alpinweiß/Black
Originally posted by Andrew325is View PostAnyone want to go for a swim? :P
I guess I'll have to get in the trunk and have someone spray water on it to see where it's leaking in. I hope they let me out after haha.
'72 2002 pickup | '88 M5 | '89 330is | '89 M3 | '01 Z3M | '11 328xi-t
Originally posted by nrubenstein View PostThe one bad thing about centric rebuilds (I use them myself) is that they are completely uncoated. In other words, if you don’t want a rust colors caliper after the first time they get wet, you’ll need to paint or coat them.
