first BMW, first E30 1985 318i
    Originally posted by lukeADE335i View Post
    Nice - the 1MZ would probably be my pick. The sound + torque would be worth it, and those engines can be had for peanuts.
    Sounds like good plans for the e30 - a 4 door might have been more practical with the kids on the way. I've found mine good with 2 kids, and used it as my daily until late last year. I daily an e92 now and they clamber in and out of the back of that just fine. Might be a bit annoying in the early years when they're in booster seats.
    When doing the school run in the e30 surrounded by SUVs, the kids used to say - your car might not be the biggest Dad, but it's definitely the loudest :)
    yes the 1mz is sooooo cheap. the only advantage of the 3vz is the fuel system is nearly identical to the stock motor (5fse) which makes getting it through california bar easier. the 1mz is returnless which is obviously harder to deal with. but the 1mz is my first choice, all will depend on what kind of deal i can find. whichever one i get cheaper will be the one i pick lol.
    hahaha i have to laugh at the "not the biggest but the loudest". kids are so honest lol!
    yah for sure the coupe will be a little rough when the kids are young and have their car seats but if i can hang on for a few years like you said, it should be fine when they are a bit older. fingers crossed!
    Originally posted by Jaxx_ View Post
    M10 ftw. Welcome! Love the SW20 too. It looks like you're well on your way already. Just a 325 sway bar in the rear will make the car nearly perfect, in my experience.
    If I recall correctly you actually need the trailing arms from a disc car to convert the drums in the rear. It's been years, so I could be wrong. The early cars also have skinnier front strut tubes, so if you plan to replace them I recommend getting the "beefer" 51mm ones. Check out the dollar bill trick to confirm size.
    sweet! thanks for the tips! im a super bmw noob so im trying to soak up as much information as i can. 325 rear sway is an upgrade... noted! also i have so much reading to do about suspension... im gonna revisit my options when the car runs a bit better and ive gotten a few of the other things on my list done.
    the PO gave me a set of 325i trailing arms so i got lucky there! but i think they might need new wheel bearings and a lot of sanding to get the surface rust off. which is actually a great Segway into my next update.
    so i haven't had a solid block of 2 hours in order to get the car in the air and bleed the brakes so that hasn't happened yet but it will very soon.
    also i should warn you all that i am addicted to craigslist and so every once in a while when a good deal pops up, i may spring for an upgrade i don't need, or that is a little out of order of my priorities... and so, cue the new seats!
    these were too good a deal to pass up and i am super picky about how seats feel, and i really disliked the comfort seats. even though these are so mis-matched with the rest of the interior... i had to put them in anyway. sorry guys! i know its ugly but a good seat that hugs you when your shredding the turns is priceless to me. and so it has begun.
    when i pulled up the stock seats i was greeted with some coffee stainage…
    not the end of the world but kind of not cool! i pity the fool that spills coffee this badly onto my interior carpet... i would hit them with the rick james…"what did the 5-fingers, say to the face?"
    the drivers side is a little better...
    so instead of dealing with the coffee stains i ignored them, because i had to get to work and i was not getting there in a comfort seat. i will pull them back out and deal with those stains on a day off.
    that being said, i cannot commend bmw enough for the great job they did on the sport seat, it feels like recaro designed it. so nice to have a factory seat option that is actually worth sitting in.
    they are a little dirty so i have to clean them still, but i am super pumped about how good these seats feel. looks are another story but that can always be fixed.
    i had to go to home depot for a couple 5 gallon buckets and used the opportunity to buy a few things for sanding and grinding...
    ive only been able to put about 20min into working on the 325i trailing arms but my intention is to clean all the surface rust off, put in new bushings and wheel bearings and get my disc setup going. so this is the start of that...
    you can tell im dragging my feet on the vac leaks...
    The beginnings of my early model 318i build
      Nice Seats ! Nobody will knock you for buying those, especially if they were a good deal.
      A couple things I noticed from your interior pic.
      #1: Dash has been swapped as the 84/85 m10 had a seat belt warning light in the middle of the dash, so I’d double check to make sure the right VIN plate is on the dash. Easy to swap so hopefully they did that
      #2: should you decide to eat one the Euro Analog clock is a plug and play conversion to the hideous useless digital clock in there now. A solid upgrade IMO
      I like where this is going, keep it up
      Simon
      Current Cars:
      -1986 BMW 325e & 1968 Datsun Roadster 2000
      Previous Car Count : 21 ... and climbing...
      Originally posted by Melon
      Let it be known to all. Simon fucking keeps it real.
        new update: lots of work not on the car
        awesome thank you for pointing that out! the dash is super cracked and I've been brainstorming what to do about the interior... I was worried about keeping the original dash but if that one isn't original than I won't have any problem replacing it.
        yes euro clock is definitely on the list! that is one of those things ill ask the fiancé to get me as a birthday present or something lol.
        ok so this update won't be that interesting but i have made progress on a rookie mistake that i made.
        i traded my old comfort seats away when i picked up the sport seats. and also with them, the buckle receivers, which probably most of you know puts me in a predicament because i have the short seat belt buckles in the 85.
        so i found this thread:
        https://www.r3vlimited.com/board/sho...uckle+reciever
        and then headed to the yard.
        there i found lots of e36 cars but nothing i could use. and then i saw the ol girl.
        take a peek inside
        seats yes... and... could it be...
        F**K YEAH! BUCKLE RECIEVERS!
        they work a treat on my early model buckles... BUT WAIT! there are a few differences between the e30 receiver and the e28 receiver.
        you can see the early style button, but the mounts at the bottom are obviously different and the angle of the bend is different as well. mine have been bent a little to be closer to the e30 shape.
        also saw this there...
        should i be looking at those rotors and calipers? anything else off that car i should be going back for?
          ^those are the brakes you want, you'll want the whole front strut housing/assemblies too and rear trailing arms. It'll be a pain in the ass to remove but totally worth it. 6cyl brakes are considerably better than those from an m10 car. I'll be doing the swap on my car pretty soon so feel free to hit me up with any other questions you might have.
          That also has the front swaybar you want (21mm) and possibly the rear (12.5mm), remember to take the hardware too!
          1984 Delphin 318i 2 door
            well I didn't have the time to go back for those parts but I will slowly be gathering the 6cyl brake stuffs and someday ill even put them on my car lol
            for now I do have an update, it's not much but its something. same thing I had to tell all my girlfriends...
            seems like they should fit pretty well, maybe needing a little spacer in the front but im thinking these will do well for giving the car a better stance on a budget. I have a friend willing to give me some 15" azenis he needs to get out of his garage and I got a pair of 15" s-drives with these wheels. so all I need to do is take all the wheels and tires to my buddys shop and mount them, then see if they need to be balanced lol.
            next update: cleaning the engine bay! and probably pics of the wheels on the car I hope
              haha I've got everything and still havent started the swap...
              You shouldn't need any spacers for those wheels but you might once you've got the bigger brakes on. I had 15x7 92's and had to run a 5mm spacer up front to clear the caliper. Definitely needed more camber than I had to not ruin the fenders. I was running 205 55 r15's as well.
                Great looking car..... You are well on your way to having a very nice ride. Good luck
                  first priority is rolling the fenders (I have a fender roller just need to find the time... I'll take pics) then I will get 205/55r15s, ive been hawking all the tire and wheel threads and I think for a 15" wheels that size looks the best.
                  thank you very much! so far my ownership of the e30 has been super enjoyable. a chassis with a lot of character and very solid feeling. everyone keeps asking when I am going to paint it... it seems that non car people underestimate the expense of a halfway decent paint job!
                  ok so normally I could throw some money at a car like this and i'd be able to update this thread with pictures of cool bolt on parts all the time and whatnot but my wedding is in 11 days. so things are progressing slow atm. and budget is ruling the build currently.
                  because spending is a concern right now I acquired 2 pairs of free tires from friends. unfortunately they are not the same size. not even close. I took them to my buddys shop, and mounted them anyway. sorry not sorry.
                  with drifting as a background I have no problem running this setup temporarily, until I can afford to put 205/55r15s all around, but it offends people lol. the fronts are falken azenis 205/50r15 and the rears are 195/45r15 yoko s-drives.
                  LOL!
                  but free is free and so here we are.
                  obviously the azenis are pretty effin sticky so I put them on the front. not ideal for looks but from a performance standpoint there was no way I was going to put s-drives in the front and azenis in the back. the front tires rubbed a tiny bit so I needed to run a 5mm spacer to clear.
                  it drives fine but the speedo is off, and I need an lsd asap so I can burn these rear tires away. I ordered a wheel stud conversion kit, and I will run 5mm spacers all around.
                  while at my buddys shop I saw these in the corner... are they worth anything? he said he'd sell them to me super cheap.
                  also I have another friend who has these for sale but they are out of my budget at $2k
                  16x8 +15mm
                  uuuggghhhhh if only I weren't getting married...……..
                  anyway that's all I got for now. i'll update again when I roll my fenders and get some tires that actually fit the car.
                    L-Jetronic M10! I've spent many, many hours dealing with these. If you have any questions, ask them here or PM me and I'll be glad to answer.
                    Worth asking, how is the idle quality? I ask as you mention vacuum leaks - they are definitely a factor, though every M10 I've encountered so far has needed an Idle Control Module.
                    IMG_0145 by Jonathan Martin, on Flickr
                    e30 m52 Build + M42 DD Log: http://www.r3vlimited.com/board/showthread.php?t=323509
                    e32 m70 (sold): http://www.r3vlimited.com/board/showthread.php?t=374756
