E30 1990 Alpin-weiss 2 - M50B25 - (MAZI) (E30 M3 5LUG SWAP!!)
    Originally posted by Northern View Post
    I have two short ones, audio isn't great on either but they get the point across.
    https://youtu.be/pbN-fvVJhmE
    https://youtu.be/YZYiM0lUnTg
    After turbo with external mic under the hood:
    https://youtu.be/tJzrilZ7d7Q
    Nice!
    what turbine housing are you running on the S257 SX-E ?
    BMW E30 M3 - S50B32
    www.e30.is
      Originally posted by Mazi! View Post
      Nice!
      I'm using a T3 to 3" Vband 0.82 A/R housing from AGP Turbo. I already had bought the T3 manifold or else I would've used the normal Borg Warner 0.8x AR T4 housing.
      Might consider a smaller A/R if I had a low comp motor.
      Originally posted by priapism
      Originally posted by shameson
        I went to a test drive after the M50 swap and the differntial lock slipped in every turn....
        So i bougt a refreshment set from racingdiffs,, ordered the stage 1 kit with 40% lock
        Diff is out!
        Cleaned it
        Everything apart
        This is ready for blasting
        Lock dissasembled
        Here are the old LSD discs,, very worn and bad condition
        New discs
        Lock ready
        Painted the housing
        Stuff from blasting
        2layers of clearcoat
        Now its ready for install
        But im not going to install it now because upcoming is full 5Lug swap and a real 5lug swap! from E30 ///M3 not some e36 shit :D
        BMW E30 M3 - S50B32
        www.e30.is
          I just sold the borbet a wheels because im going to do a E30 M3 5lug swap $$$$$$$$$$$$$$$$$$$$$$$$$$$$ :bawl:
          it is currently sitting on some trash wheels
          Bought E30 M3 version of KW Variant 1
          Also
          E30 M3 rear hubs
          E30 M3 rear brake dust covers
          E30 M3 rear brake caliper brackets
          E30 M3 rear brake pads and sensor
          and some stuff for the handbrake
          95a poly bushing kit from Garagistic
          installed the diff bushing
          As can be seen i got loats of the parts that i need already but im still buying and searching for many other parts before i can finish that 5 lug swap.
          BMW E30 M3 - S50B32
          www.e30.is
            Nice! minus the garagistic bushings.
            Make sure to put 12.9 hardware in those uprights.
              Fantastic thread! So cool that you're also building this in Iceland. Those KWs are amazing.
              OBD1 S52 E36 Compact
              84 318i M10 Zender
                Beautiful build so far, looks like you have access to a garage when you need it makes things easier, keep up the great work
                  What’s the deal with the garagistic bushings if I may ask?
