Motor Mount Mayhem
So recently I was trying to track down the source of a bad vibration felt through the brake pedal. It was thought new motor mounts would help to clear it up, so I placed an order with BMA. In the meantime, I found that it was my Power Steering pump making the noise and vibration, and I got it fixed.
So today I was bored, so I decided to throw the new motor mounts in anyway.
What should have been a 1 hour job turned into a 4 hour job. The lower nut on the passenger mount was stripped, so I ended up having to use a Dremel to remove the stud. The drivers sound mount was also a bitch and wouldn't break loose, so I had to remove my intake boot and charcoal canister so that I could get a better view and grip on the nut. All turned out well in the end, I just need to grab a new 17mm nut and washer from the hardware store today.
Old mounts:
These were so soft, one was squished like a donut, and both mounts I was able to squeeze and leave impressions with my fingers.
New mounts ready to go in:
I also ordered a new DME relay, and a new Fuel Pump relay. I was having an issue where it either took several seconds for the DME relay to click on and supply the fuel pump relay with power, or it took several cycles of the key to get it. This was the source of all my hard start/long cranking issues.
Popped the new relays in, and they click immediately, and the car starts like it's brand new. This was a relief, I've been chasing this issue for some time.
Next on my list is a Center Vent Gauge pod. Awaiting my order from HighBoost to arrive. I'm going to go with VDO Vision series electric gauges.
Volts, Oil Pressure, and Oil Temp. Already scored a brand new Volt Gauge from Fleabay for 18 shipped.
Old mounts:
