Nice 4 door early model!
Corey's S52 Swap
Thanks everyone! Didn't notice the new replies for some reason. The build is going very slow right now as I don't have much time with work and everything else. But it is coming along.
Engine still needs a wash, I'm just dreading it, haha.
Originally posted by Vivek View PostLooks like you're about 3200 in (added up a rough estimate in about 30 seconds) and you've got most of the stuff. So you're looking at about a 4k swap to put about 250 to the wheels. Looking good...
Originally posted by catuned View PostLooking good man. Update the build. :)
Let me know if you need anything.
4. Oil Pan Swap. 3/30/12
Securing the oil pump nut. New nut and safety wire from Bimmerforums.
E34 pickup tube on
Oil pan on, RTV'd of course
What mess mom?
Awesome build is awesome.~ Puch Cafe. ~ Do business? feedback ~ Check out my leather company ~
Instagram: @BWeissLeather
Current cars:
~ '87 325 M30B35 swap
~ '87 535
~ 01 540 Msport 6spd
~ '06 X5 4.8is
Haha man, I let this die quickly :(
Originally posted by Janderson View PostAny reason you went with wire rather than a tack weld on the oil pump nut? Other than not having a welder...
Originally posted by e30_neverstock View PostHey Corey, any updates?
Got a few things done recently. Nothing picture worthy.
But good god, it never ends with the parts. Here's my list of parts needed (not including the e36 m3 cats), and I know I'll find more.
Radiator Bracket: 17111709347
Radiator Bracket Screws: 17111712142 x2
Radiator Rubber Mount: 17111178412 x2
Radiator Bracket: 17111709333
Radiator Bracket: 17111178449
Radiator Rubber Bracket Mount: 17111150984 x2
Coolant Hose: 11531708499
Coolant Hose: 11531726344
Alternator Cooling Boot: 12311735915
Alternator Cooling Intake: 12311730635
Transmission Bolt: 23001222891 x2
Transmission Bolt: 23001222894 x2
Transmission Bolt: 23001222887 x3
Transmission Bolt: 07119904094
Transmission Bolt: 07129904681 x2
Transmission Dowel: 11117524470 x2
Engine Wiring Harness Cover: 51711380392
E34 Throttle Cable: 35411160609
Driveshaft Bolt: 26112283795 x6
Driveshaft Nuts: 07129900047 x6
Driveshaft Bolt: 26111206718 x4
Driveshaft Nuts: 07129964672 x4
Exhaust Gaskets: 11721435367 x2
PCV Hose: 11151740393
Throwout Bearing: 21512226729
Clutch Spring Clip 21517570284
Clutch Fork Lever: 21511223302
Pilot Bearing: 11211720310
Pressure Plate Screw: 07119906045 x6
Clutch Fork Pivot Pin: 21511223328
Accessory V-Belt: 11281437929
Charcoal Canister: 16131180886
Secondary Air Pump: 11721744490 (might need)
