★ ★ Project Glacier | Make the E30 a Daily Again ★ ★
    Originally posted by AbsorbantNut View Post
    this m30 thing is starting to sound like a broken record
    Better than a broken timing belt.....
    ....which will happen if you keep that m20.
      I forgot that M30's are chains. How bad (i.e. expensive) is doing preventative maintenance on those?
        Look what happened to Kameron. Don't be a Kameron. Don't do M30's.
        1991 325iS turbo
          Everything bad that could happen, happened to him... Good point. But, he's also dealing with boost which I wouldn't be doing straight off the bat.
            Gates brah........Gates.
            Truer words have never been spoken.
            Instagram @rebellionforge
              Easier than M20 because no belt.
              If you really wanna do chains/guides, go for it....but unless it has over 250k on the engine, I'd roll with it.
              If you're swapping heads, doing turbo things, it's more of a while it's apart thing.
              ....but it's a life-of-the-engine type thing.
              An M30 will outlive the car it's put it. This has been proven many times over.
                Bro like 250 bucks or less especially if your friends with blunt ;)
                1991 318i 4dr slick top
                Mtech 2 turbo restoration
                  Same foundation. Let's not complicate things with variables like 20 pounds of boost.
                  And what about Japandrew? He went M30 and nobody ever liked him. It's all bad man. Don't let history repeat itself. Don't become a statistic.
                  This guy gets it.
                  1991 325iS turbo
                    Same foundation. Let's not complicate things with variables like of boost.
                    Don't you put that evil on me.
                      ★ ★ Project Glacier | Stella | Fueled by DREAMS ★ ★
                      Lololol japandrew
                      Kams problem was he forgot the load plate the first time and when he did that he destroyed the crank. So when he replaced it the second time it was really just a temp fix. Boost the right setup and you'll have no issues do the right work and you won't need 20+ psi to make 350-400hp
                      As long as you don't polish your Pistons, notch your subframe and buy oem tape you should be alright.
                        Japandrew should be your end goal
                        '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
                          Beginning to think Lambo isn't man enough for the M30.
                            I had him turn in his man card way back when he spooned 205s onto his 9 inch wheels.
                            Lorin
                            The M30 is God's engine.
                              I'm sure spooning an M30 into that e30 will help catalyze getting that card back....as he will no longer be able to have 205s on his niners.
                                Kinda like how you sound all the way through the last few pages ;)
                                m30>m10>m20
                                Easy, I did a full refresh on mine before swapping for under 400.00
                                He ran a lot of boost and neglected a few key things that ended badly, he is doing it right and replacing the issues and I suppose swapping it back?
                                I am coming up on 2 years swapped without a single issue NA, I went through it and sorted any issue out beforehand and time has shown that is the proper way to go. If you want better MPG I HIGHLY suggest sticking with the m20 in there, if you want the growl of a bear I would swap an m30 ;D
                                m30 is the most reliable engine BMW has ever made besides the m10, the m20 is also very good but timing belts are for the birds. You have something going for you with the m20; it looks to run super well and it is already in the car...collect parts and start building on that! That is my sage advice.
                                Instagram: @BWeissLeather
                                Current cars:
                                ~ '87 325 M30B35 swap
                                ~ '87 535
                                ~ 01 540 Msport 6spd
                                ~ '06 X5 4.8is
