one of the PO's 02s - S14 equipped of course ala Blunt's old orange one
325ic Calypso Euro Conversion - Houndstooth & dbilas now, MT1 & MM 3.2 stroker coming
Last edited by bradnic; 03-29-2016, 11:43 AM.I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
DB vert plastic bumpers
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
you have pm.
check out the German KBA doc for the 16x7 Alpina (attached)
full Alpina info on e30.de (via google translate)Attached FilesLast edited by bradnic; 04-02-2016, 04:25 PM.I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
Jealous of your wheels. I want 16 inch alpinas
Nice 2002!! The Alpina wheels looke great....Projects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
I did see the s14 motor pic!!!!!Projects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
Congrats on the wheels. You deserve a score like that. I'm into mine about $3.5K (without tires) after restoration. All those little accessories add up quick. Great to see you got a complete set. You did good.Last edited by robrez; 03-29-2016, 12:37 PM.sigpic
January 2012 COTM
very nice thread & parts list. just an opinion I wanted to share with you though; I installed a vortech blower on my 325xi and hated it. Car went through several tunes, went up to 9 PSI of boost but the car still felt anemic. I'd personally steer clear from a centrifugal blower, but that' just my 2 cents. I'd pair what you have there with a nice 2.8-2.9L bottom end and an aggressive cam.
Originally posted by robrez View PostCongrats on the wheels. You deserve a score like that. I'm into mine about $3.5K (without tires) after restoration. All those little accessories add up quick. Great to see you got a complete set. You did good.
Originally posted by Julien View Postvery nice thread & parts list. just an opinion I wanted to share with you though; I installed a vortech blower on my 325xi and hated it. Car went through several tunes, went up to 9 PSI of boost but the car still felt anemic. I'd personally steer clear from a centrifugal blower, but that' just my 2 cents. I'd pair what you have there with a nice 2.8-2.9L bottom end and an aggressive cam.
Stroking and camming the motor will get some/all of the lost midrange torque back and more, but what a waste! It seems that if you want NA drop the dbilas enjoy the power and torque gains!. The rational person would either keep the stock manifold or get "real M20 ITBs". 3 options other than full custom ITBs:
1) stick with the dbilas and source the M20 CF airbox for it. Not a real option as the company's website is not functioning. I assume they're out of business.
2) sell the dbilas and go RHD ITBs.
Digger would certainly agree :-)
3) The only other ITB option I know of is the H27SP but Raul/e30m3s54turbo tells me they were made by Schrick for Hartge and cost $6k new! They're basically impossible to find.
What do I really want? A flat torque curve and about 40-50 more hp than stock. So... if I'm weird and OCD and want my damn dbilas even though it eats midrange torque, I end up having to consider FI.
As to turbo vs SC, I think I wrote a while back that I'd consider a log / TCD style turbo manifold. But I've done intercooled turbo setups and I just don't think they're right for this car. That leaves me with a compact supercharger as the remaining option. There's no room for a roots system with that dbilas plenum - or is there? there's actually alot of room under the plenum...
Between that and the need for serpentine drive, there's alot of thinking to do. In the meantime I'll do a 'stage 1' dbilas+M30 AFM+19# injectors+tune. Then I'll stroke and cam the motor and headers and MS2. We'll see where we end up at that point, probably next year.Last edited by bradnic; 03-31-2016, 06:02 AM.I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
Originally posted by ThatOneEuroE30 View PostJealous of your wheels. I want 16 inch alpinasI BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
Originally posted by bradnic View Postthey're out there man. one step at a time. get that zobelbraun beast sorted. so much rare goodness in your car!! and all that time you've put into it. I'm really looking forward to seeing it at some point.
Hopefully soon... I sold all my race car motor parts:( gotta fund the rebuild.
Originally posted by bradnic View PostOriginally posted by whodwho View PostNot sure how well that cruise control cable mod will work, when you apply the throttle the cc cable will not be pulled at the same time.
You might be able to to fit a spring loaded pulley/tensioner to take up the slack so it won't derailOriginally posted by bradnic View Postactually they're both on the same shaft so they'll rotate together - at least I hope they will lol. it's a ways off so I'll have the chance to try things out.
this last one is key - the cables mount to a bracket that rotates with the shaft.. good to know
Last edited by bradnic; 09-03-2017, 10:29 AM.I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
Originally posted by bradnic View PostWell that was fast. Every single part is NLA despite being orderable through the catalog.
Thank you for ordering from BMW Parts and Accessories .
We regret to inform you that the following 21 items are currently unavailable:
51711942967 AIR CHANNEL
51711942968 AIR CHANNEL
51111959739 COVER EURO
51111959740 COVER EURO
51111919154 LABEL
51711953903 TOWING HINGE
51121942083 RIVET
51121919155 BRACKET
51711919169 BRACKET
51711926202 BOLT
51711926201 8-STRIP EURO
51121953905 6 LABEL
51121953890 8-BRACKET EURO
51111953715 8-FOIL EURO
51161881149 8-FOIL EURO
51111942081 BRACKET
51111942082 8-RIVET EURO
51111919151 8-BOLT EURO
51711937627 BUFFER STRIP
51121932230 BUMPER STRIP EURO
51111953713 BUMPER STRIP EURO
Reason: DiscontinuedOriginally posted by bradnic View Poststill ticked about the MT1 parts order going south. Looking into ordering with a euro vinOriginally posted by Sirotto View PostIts not that they're not avail but they are all blocked. It is way past the safety dot issue now. If it was not available on a us car you can not get it anymore no matter what it is.Last edited by bradnic; 03-30-2016, 05:14 PM.I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
Originally posted by doorman View PostWhat's the reasoning behind not allowing euro parts in the US?
Emissions, safety?
Originally posted by doorman View PostI like this one......51111942082 8-RIVET EURO......must work differently then our US rivets!!!
Last edited by bradnic; 09-03-2017, 10:30 AM.I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
