Scum class 318 + Mtech + vortech v2 + unicorns - vortech + Turrrrbo
    That front end. om nom nom
      Lord this is awesome! Mtech1 is the jam.
      -Nick
      Originally posted by 87e30
      First of all: calm the fuck down; second of all; cool story bro.
        $400 for a tech 1 kit shipped over.?
        Last on over here went for nearly £700 without postage.
        Gone are the days of even us finding cheap Tech 1 kits anymore, as they are in more demand than the Tech 2 kits.
        Nice car BTW.:D
        If you have bought items from me, please leave feedback below.
        If you are a BUYER, Check My Feedback.:up:
        http://www.r3vlimited.com/board/showthread.php?t=183860
        Check out my Euro Build Thread
        http://www.r3vlimited.com/board/showthread.php?t=215557
          Nice car BTW.:D
          I found it for 270 Pounds on ebay UK, with the bumpers
          I had seen a few sets at wreckers in Germany but they were all rusted out/broken
            That's a good price.
              beautiful build
              sales@blunttech.com
              www.blunttech.com
              Like us on Facebook
                Originally posted by RUFFLZ
                let's see it on the ground!
                I'm afraid it's too late for that!
                yay airtools!
                Burned the bushings out
                That's all for today, my back hurts from squirming around under the car
                Pulled the rear calipers, they are rebuilt, less than 1k miles on them, up for sale if anyone wants them, I'll be using 750iL brakes
                  got the RTABs out. Used a 36mm socket and 6 inch C clamp
                  it kept sliding off so I cut some PVC tubing with a slot in it, so it sit semi flat
                  PO must have replaced the RTABS, pretty good condition
                  Got some goodies in the mail, bolt-in rear sway bar mounts
                  My TAs already have welded mount
                  excellent fitment and quality, and cheaper than the welded sheet-metal type
                  only issue was some of the hardware was improper length, only 2-3 threads were engaging into the mount
                  installed
                  nice plate to keep from ripping the hardware out of the sheet metal
                  I've also pressed the bearings out of the rear TAs, no pics of that because I was busy cursing, it was a PITA
                  From just mocking up the e36 hubs look to be a direct fit (they use the same exact bearing as e30 hubs)
                  on top of that they will reduce the rear track width by about 10mm on each side, which means more room for wider / lower offset wheels
                  will find out soon
                    Here is the comparison between standard e36 (non Ti non m3) rear hub and the e30 rear hub.
                    the e36 hub is about ~12mm shorter. The result of that means the brake rotor will be 12mm closer to the dust shield / e-brake / caliper mount / etc.
                    The rotor I'm using will actually make contact with the dust shield, so I trimmed it like so:
                    The e-brake mounts to this dust shield, and Im keeping the e-brake for mad skidz!!
                    That bent tab is the brake line mount, I left it on so the brake lines wouldn't just dangle
                    mounted up
                    The dust shield is cut at a diameter of a little less than 160mm, just enough so that it can actually fit inside the rotor, and allow the rotor to come in the full 12mm, here's a pic of that ( I haven't received my rotors just yet, but the stock rotors have the same inner diameter, so I used those for the time being.)
                    The inside of the rotor actually has a machined surface that allows the e-brake pads to grip
                    So here arises the next problem, the rotors have a small lip deeper in the hat, you can sort of see it here
                    I hope I can adjust the e-brake enough (move the pads closer together), to clear this lip.
                    the lip is slightly larger on the rotors I'll actually be using, the stock rotors clear just fine.
                    The consequence of this will be increased pad wear, as the pad will be riding on the lip, and the surface is rough (unmachined), but I'm okay with that.
                      So the e36 hubs are a no-go. the lip inside the rotor is much larger than I expected.
                      It won't be possible to retain the e-brake without running brake rotor spacers.
                      Rotor spacers would probably run me $200+
                      I ordered up a pair of e30 m3 hubs instead for $140 each
                        uwww damn! This build delivers.
                        Click here to leave me feedback on our transactions. :p
                          do you plan to reinstall the dust shield. i'm thinking you might catch a lot of debris between the rotors and pads without it.
                          Much wow
                          I hate 4 doors
                            awesome, hope to see this in person one day
                            Simon
                            Current Cars:
                            -1999 996.1 911 4/98 3.8L 6-Speed, 21st Century Beetle
                            Make R3V Great Again -2020
                              Yeah i'm gonna go to picknpull and pick up another set of dust shields. Just gonna cut the outer lip to clear the larger rotors.
                              I think the shields main purpose is to keep debris out of the handbrake mechanism, don't think it does much to keep stuff away from the calipers.
                              On my last e30 I was doing some spirited driving on hwy 9 and a small rock wedged itself between the pad and rotor, the pad overheated immediately and the fuild boiled. Lost all brakes doing around 75mph on the straightaway, think I pooped a lil :o
                              I wish I kept that rotor, had a nice slot ground almost all the way through one side
                              this was with the dust shields on.
                                i now regret taking my dust shields off
