Originally posted by Albie325
View Post
Paint Prep Round #2 - More Rust Repair, Another Trim Set
Continuing on with the theme, I tackled some more rusty areas.
Felt good to fix these spots, as I've been looking at some of them since I got the car six years ago.
Driver's side rocker, passenger side under rear bumper surround, and the trunk all needed attention.
Thankfully I had a donor damaged trunk to cut a patch piece from, which made that job easier.
I also picked up another set of painted trim. I was mostly interested in getting a straight rear DB trim piece so that I could line up the rearend trim when fixing that quarter panel.
Unfortunately I forgot that all 'verts use the lower rear arches, so I won't be able to use the rear DB side trim pieces. I will have to make due with the set I have.
The new front trim pieces fit really well, except for the middle where they appear to rise up. I will put the front bumper back on and see which set of trim fits best.
I started on the passenger side door rust spot today (under the door moulding). I got all the rust cut out, next job is to fab and weld a patch!
