Use studs on the header. Over the years, I have never had luck with aluminum heads and header bolts. Studs with stover nuts has been the choice.
Also, if you bead roll or put a weld bead on the end of your pipes, you will eliminate coupler leaks. (I have also seen the "poor man's" strap where they put a strap from pipe to pip over the coupler to keep them from popping, sorta like this...
Too bad you moved so far north. I probably have a CHRA you could borrow and/or a stock exhaust so you could go to Spectoberfest. :/
I spent a few hours trying to weld a nut to the stud and back it out last night and failed, I need to get some nuts that aren't contaminated beyond what a wire wheel can fix. Now I'm working on stuff for school and don't know if I'll have time to fix this before the school week starts. I'm so glad I couldn't replace the other studs when I got my new hardware in months ago because I couldn't remove them without taking the header off, they may have all broken because I was torquing them down pretty tight to compensate for a warped header flange. The stud didn't break when I torqued it down, it stretched, and when I went to remove the nut that's when it failed.
