Bronzit E30 - OBDII S52 shaved bay - weekend/autox toy - Journey
  • Digitalwave
    is a poseur
    • 6281
    #1771
    You can thank me for those Condor rocker wiring covers
    Can't say as though I agree with removing the ABS, given your use of the car. Do you plan to run without it, or to swap in the MK60 system now?
    RISING EDGE
    • Sh3rpak!ng
      • Jan 2014
      • 2667
      #1772
      Ha! Good man. I had a feeling you might've had something to do with it. You have my thanks.
      As for ABS - here's my rationale:
      - I don't have the budget right now to either refurbish the original system, or do the MK60 upgrade (nor do I have the time or interest to take on such a large scale project at the moment)
      - The ABS system currently is not working at all
      - My brakes are not performing as they should (and this is likely due to non functional ABS)
      So given the choice between keeping non-functional ABS + underperforming brakes OR no ABS and good brakes, I'll at least take a fully operational brake system for the time being. So yea, I'll be running without it for a while. I very rarely drive it on the street these days, and when I do it's just an early morning canyon run + local cars and coffee. If I were driving it more regularly in traffic I'd be more concerned. Besides... I know a handful of porsche guys driving old 911s without it :p
      Shadetree30
      • Sh3rpak!ng
        • Jan 2014
        • 2667
        #1773
        Finished bundling and tucking wires. Finished the driver floor plate. Made a dead pedal. I am pleased with how the interior is turning out. Sent from my SM-G960U using Tapatalk
        Shadetree30
        • amcp
          • 489
          #1774
          Looking good.
          Pro tip, the wiring harness that's between the seat and the trans tunnel for the windows can be moved outta the way for a cleaner look. It can be routed through the channel in the chassis with the rest of the wire bundle then fed behind through the knee panel.
          I did it when I gutted one of my old cars.
          • Sh3rpak!ng
            • Jan 2014
            • 2667
            #1775
            Originally posted by amcp
            Looking good.
            Thanks - yea I noticed that while I was organizing it. I was getting impatient with the whole process and just opted to clean it up and leave it as is for now. I'll reroute it sometime in the future. Like if I ever get around to spray coat the floors with lizardskin heat/sound deadening....
            Shadetree30
            • Sh3rpak!ng
              • Jan 2014
              • 2667
              #1776
              Damn. Didnt realize its been 2 months since I last updated. Lots to share. As usual the tapatalk photo upload is going to put them all out of order... I'll go back and edit with more comments later. See if you can guess the projects.
              Bracket for mounting the dead pedal. It sandwiches the aluminum.
              Driver panel getting finished. Monster countersink to mount the allen countersink bolts flush. Delrin to make stand-offs.
              Went for a drive
              Reminder of how nice the engine bay looks
              Cockpit looking fresh
              Small garage upgrade. Added a compressed air regulator and filter to the workbench with short hose for using air tools at the bench rather than tripping myself on my big hose. Put a mig torch holder too.
              Small house project. Made floating shelves from some walnut wood. Put a bevel to match our "mid-century modern" style
              More engine bay
              More garage updates. Hung more air tools. And those are the floating shelved pre-finish
              Finally time to replace my OG revshift swap mounts. I think they served me well over ~7years getting baked by the header. I know many have had their complaints/issue with revshift, but my experience was great. The mounts fit perfect.
              Bigger photo of the whole workbench area. Really starting to come together.
              Mishimoto radiator leaking... been slowly getting worse over the past 1-2 year. Not sure who's fault, mine or theirs. I had coolant pressure issues years ago. Good news is that it took 4 days, no questions asked and I already got a warrantied replacement.
              So careful draining coolant not spilling a drop...... and then I kicked the bucket over when I shoved the jack under the car not looking...... DOH!!
              Ground down the welds on my header to make it look a little more pretty
              Leaking coolant extension drain. I'm just going to put a plug back in the block. This was really tight against the headers.
              Little out of order, but this was pre grind
              Repeat photo? Looks cool?
              Final grinding on headers after the new flex joint was welded in place. Finger sander is a weapon.
              Here's why I bothered grinding. Ceramic coated the headers inside and out. Also had the engine arms powdercoated silver.
              Started making fender liners from spare 1/8" ABS
              Inside the header ceramic copper
              Pre-fender liner. ABS unit gone. Much more space.
              Shadetree30
              • MR E30 325is
                • Dec 2008
                • 3299
                #1777
                Always excellent work, as usual!
                My previous build (currently E30-less)
                http://www.r3vlimited.com/board/showthread.php?t=170390
                A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
                • 2mAn
                  SeƱior Mod
                  • 20178
                  #1778
                  Looks like another Mishimoto Radiator warranty claim...
                  Simon
                  Current Cars:
                  -1966 Lotus Elan
                  -1986 German Car
                  -2006 Volkswagen Jetta TDI
                  Make R3V Great Again -2020
                  • amcp
                    • 489
                    #1779
                    Seriously, note to self on what not to pruchase.
                    • Sh3rpak!ng
                      • Jan 2014
                      • 2667
                      #1780
                      Yes... Idk what to think. The top and bottom caps were both slightly bowed which possibly indicates pressurization of coolant? Or maybe just low quality... I don't remember if I already replaced the rad after I had my head redone due to coolant pressure, or if this actually is the replacement.
                      At any rate, mishimoto sent me a brand new radiator which took 4 days start to finish from warranty claim submission, to new radiator on my porch. And I was going to drain the coolant anyway to replace my expansion tank and remove my leaking "block drain extension" (which is also in the way of the headers)
                      Shadetree30
                      • amcp
                        • 489
                        #1781
                        I'm just leery of aftermarket parts that are "supposed" to be better over oem then stupid issues like this pop up. When you can roll an upgraded oem rad for yrs and not have issues.
                        When traveling to DEs that are 4-8hrs away from home I want my shit rock solid.
                        Dont wanna crap up your thread so I'll step off my soapbox.
                        • 2mAn
                          SeƱior Mod
                          • 20178
                          #1782
                          Glad to hear that at least Mishimoto is quick with the replacement and that you were planning on draining it anyways, so not a huge PITA
                          Yes, you should be posting a thread about your cars anyways... why are you hiding the goodness from us. Are you ashamed of YOUR Bronzit car? lol
                          Simon
                          Current Cars:
                          -1966 Lotus Elan
                          -1986 German Car
                          • Northern
                            • 5074
                            #1783
                            What's the story with the revshift mounts? Bought a set myself recently because of their most recent redesign, but look exactly like these ones?
                            Originally posted by priapism
                            Originally posted by shameson
                            • Sh3rpak!ng
                              • Jan 2014
                              • 2667
                              #1784
                              Yea, hahaha you guys seem more upset about it than I am at this point. I'm really not irritated at all. The warranty replacement was my only trepidation, but it couldn't have been easier.
                              More bronzit!!
                              I've had them on the car since I did the swap and I have enjoyed great performance from them. Fit was spot on too. It's just time to replace them at around 7 years age. That one in the photo was from the driver side
                              Doesn't bother me at all. Years ago when I bought it I did so because of the budget allure and warranty. To be fair it also didn't all-of-a-sudden spring leaks... it's been slow leaking and getting progressively worse for about a year.
                              Shadetree30
                              • Reichart12
                                • Aug 2012
                                • 2150
                                #1785
                                I really like what you've done with the floor and pedal area.
                                Instagram: Reichart12
