Originally posted by tiger_e30
View Post
The Journey of Linda and Friends - the M20b31 Lives
The E36 is "done", aka I'm not doing anything else to it before I sell it. The car cleaned up very well, and despite the fact that whatever lowering springs I was sold are INSANELY low and look like ass, the car rides 100,000x better with all of the fresh bushings/struts throughout the car. I really, really want to find a nicer E36 some day, they are great cars.
The poly RTABs with the sandwich bushings to secure them better in their mounts.
On the E30 I re sealed the diff and installed it onto the rear subframe. I began re-booting my rear halfshafts, only to realize the joints are too far gone, so I had to order remans from FEQ which are supposedly decent quality.
I inspected a few things and found that my fuel feed line on the E30 is shot, so I ordered one. I also ended up having to order a speed sensor for the diff as the one I had was very brittle.
"its the little things"
Trying to get through all of the small things I need to do before I can put the rear end back in the car and drop the front end. Seems like a never ending process.
Both the rear brake lines and fuel feed line were rusted out at the clip before they head up into the bay. I got an OE fuel feed line (thanks DealinDave!) and went with the Chasebays brake line kit. A little bummed I can't use the factory clips for the brake lines, as it just adds yet another "project" within this project. I also got the new ebrake cables up, new fuel filter, FEQ axles, new diff sensor, etc.
Just so you can laugh at me, I originally dropped the rear subframe to put new bushings in it, and it ended up as
adjustable subframe
poly bushings (ta,subframe,diff)
wheel bearings
hubs
ebrake cables/shoes/hardware
diff reseal
speed sensor
axles
abs sensors
trunk tar removal
braided brake lines front to rear
fuel feed line
konis
ground controls
upper strut plates
rear swaybar reinforcement
billet swaybar mounts
Recent pics
Originally posted by tiger_e30 View PostJust curious how much time do you think the swap will have taken? Trying to figure out if I want to do a swap, cam and itbs or turbo
I dealt with the same battle.
IMO youre going to spend the same amount (or less) as M20/cam/ITBs on a 24v swap like this one and have a far better foundation to add onto in the future.
Turbo is a constant reliability concern IMO so unless you're willing to tackle that, I personally think going 24v is the best bang for your buck as it applies to simplicity and reliability.
If you wanted to do it on the cheap an M52B28 is the way to go. Bolt it up to your G260 and let her rip. People do the swap in a weekend if the chassis is ready for it.
Originally posted by fight4life28 View PostSir you have addiction, And maybe love to break e30's for parts =) Keep up the good work. Hard to slack on not doing things right when its right in front of you at the time being.
You're right about that. The car is taking much longer than I expected but I think it will be very rewarding in the end. And then I can start on the M3!
Originally posted by AWDBOB View PostEverything up to this point has been chassis related, but I plan on keeping a pretty detailed log of the actual swap portion of this build once I get the rest of the car sorted first.
Sent from my SM-G920V using Tapatalk
Originally posted by tiger_e30 View PostYou going to mod the m50 at all? Have a s50 with 180k on Craigslist tempting me
Think he might let it go cheap
Sent from my SM-G920V using TapatalkOriginally posted by tiger_e30 View Post
S50s and S52s were so expensive when I was looking, and they all had high mileage with unknown history. I got a complete M52b28 with harness and accessories for $450 and M54b30 internals for $350 to make an S50 style 3L.
Originally posted by AWDBOB View PostI have an M52b28 longblock. I also have a M54b30 rotating assembly that will going into the M52 block to make a cheap and fresh 3L. Compression is somewhere around 10:1. I also have S52 cams for the top end.
S50s and S52s were so expensive when I was looking, and they all had high mileage with unknown history. I got a complete M52b28 with harness and accessories for $450 and M54b30 internals for $350 to make an S50 style 3L.Simon
Current Cars:
-1999 996.1 911 4/98 3.8L 6-Speed, 21st Century Beetle
Make R3V Great Again -2020
