Project Weißer Regen: 91 318iS Restomod
    The end result from vapor blasting is really impressive. Wow.
    2000 A4 1.8TQ | 1988 325is | 1976 280Z | 1953 CJ3B
      I know this is meant to be a pretty oem original rebuild, but have you considered upgrading the lower timing case to the later m42 version? Much safer design that eliminates the idler wheel and the potential flaws in the early castings that have been known to fail.
      Just something to think about before you put it all back together!
      -NICK
        With the vapour blasting, do you need to do anything to protect the metal after its blasted? Or is it good to go right after blasting?
        Steve • Toronto
        1991 318is • Brillantrot
        Build Thread
          Originally posted by ThatOneEuroE30 View Post
          Are you planning to still run the throttle body heater and the rest of the mess?
          I intent to restore that back to OE appearance, but I may not actually plumb the coolant loop in. We'll see when I get there.
          I'm aware of the inner timing case failures, but its really a non issue blown out of proportion by the internet.
          I guess that depends on where you live. Down here in Texas cast aluminum stays bright an clean for years. Up where you live? Salt in the winter air probably starts dissolving it right after it leaves the machine
          In the case of those that live up north with liberal applications of sodium chlorinate on the roads I'd say yes either seal it, or don't drive in it.
          Hers 13 X3 375hp/450tq - His 14 M5 780hp/730tq
            Started to reorganize a few things and pull out some new parts to put a few sub assemblies together.
            Freshly plated studs reinstalled in lower intake manifold
            Shifter linkage
            Steering column, which was blown apart to be able to plate the main housing bracket and vapor blast the ignition lock housing.
            Close up of the bottom bearing with spacer and dust shield
            Top side
            Fully reassembled
              Simply amazing!
                Hmm I wonder if it would still be a factor with a 'summer only' car.
                Either way, how would you seal it?
                Steve • Toronto
                Build Thread
                  Oh I am going to say is wow - I need to start taking notes - Much respect
                    Your attention to detail is awe-inspiring. I'm taking copious notes.
                      Love the eye candy! Those tires fit the Euro weaves nicely too.
                      Classic BMW Specialists
                      Santa Clarita, CA
                      www.BimmerHeads.com
                        The vapor blasted surfaces look great. Never had heard of that process before!
                        The cad plated bits look great, Im liking it better than polished/stainless/powdercoat!
                        -Nick
                        M42 on VEMS
                          If you guys haven't heard about vapor honing before, Jay leno had a specialist on his show.
                          https://www.youtube.com/watch?v=30HBumz3zJ4
                          We're in deep now boys
                          1988 325i SETA - Daily driver
                          1988 340iL - Track car
                          My M60 V8 swap thread here
                          [oo==OO==oo]
                            I don't think its going to be any kind of issue down here in Texas anyway. My 14 535i daily driver still has pristine aluminum components, as does my wifes 13 X3 and both cars are year round dailys.
                            You and me both, thought about getting a machine for the shop yet?
                            I'm happy with the tire choice, they are nice and square with the wheel protector lip sidewall design.
                            This build exists largely because I found this process ~6 months ago and I knew I had to build a car around it. Thats a good video for the process, although it take a lot longer than that (Video was cut to make it look faster)
                              I've been looking for a nice set of late model tail lamps this whole time and it *just* occurred to me I could probably buy them new. Sure enough they were still available, and about $225 for the pair was a no brainer IMO.
                              They come super shiny of course, and with plastic film over the lenses for protection.. and nice supple gaskets.
                                Wow 225 for the pair is cheap! Early model ones are 280 a side last I looked.
                                1991 318i 4dr slick top
                                Mtech 2 turbo restoration
