Project Weißer Regen: 91 318iS Restomod
  • quasi mofo
    • Dec 2016
    • 107
    #1081
    Originally posted by Jordan
    Having difficulty sourcing the fabric right now, no real progress to speak of.
    Thank you, I do intend for this car to likely be my magnum opus, and while I'll surely take part in Jon's New M3 shell build I likely won't take on another of this scale myself.
    Door plastic sheeting 51951924961
    lol, that slow today?
    Awesome. Thanks!
    • zaq123
      • Jul 2016
      • 1364
      #1082
      looks like e30 came with two different types of the moisture barrier....my 90s e30 has gray plastic with some felt fabric and it was attached by butyl cord. 89 e30 had clear glued plastic as in this thread.
      • Jordan
        • 12907
        #1083
        Originally posted by CaptRiskyBiscuits
        What adhesive do you use for the vapor barrier? I've never actually seen one look so clear and clean lol
        It is self adhesive film. It comes applied to contact paper, peel and stick after you cut it out.
        https://mtechniqueabs.com/
        • mjweimer
          • Dec 2015
          • 649
          #1084
          Jordan - thanks for posting the vapor barrier part number. I've been following along with all of the updates and enjoying each one. Keep up the great work!
          MJ
          • slammin.e28
            שמע ישראל
            • 12054
            #1085
            Meh, I find time lol. Really making me want to tear into this e28 heavily tho....need to find that time.
            • E30 Wagen
              • Jul 2005
              • 3425
              #1086
              Even though I all my e30s are gone I still like checking in here just to see progress on this. Great work as always and a good source of info for anybody undertaking a restoration like this.
              My Feedback
              • Jordan
                • 12907
                #1087
                Alllllright, I've enjoyed an enormous amount of progress over the last few days but I have not been able to share it here as Photobucket has been DOWN. At the moment it is letting me log in so I'm going to try to snatch some photo links. If for some reason you can't see the images just try back later...
                As of 3pm on Christmas Eve my pistons arrived from JE, a Merry Christmas it shall be (well for me anyway, wife is less than thrilled)
                Unpacked from the carton, with the pistons marked with a sharpie arrow as the intake and exhaust valve reliefs are different and these only go in one way!
                I filed all of the rings to fit and assembled the first ringed piston and rod.
                All four pistons, rods installed and rod caps torqued to spec
                Hello down there
                From the top, so pretty. Shame this all gets buried inside.
                87mm headgasket options are limited. I elected to go with the Athena 87m MLS headgasket.
                Not taking any chance with the profile gasket leaking.
                Cylinder head dropped on, bolts hand tightened.
                Head bolts torqued to spec, camshafts set in their journals with the caps loosely installed
                Timing gear all assembled, engine timed.
                Upper and lower timing case covers installed and torqued to spec
                Add new thermostat housing, water pump pulley, and harmonic balancer/main pulley
                Lower intake manifold assembly installed
                Add some hoses
                When everything is new and well lit its really not such a mess under the intake. Oetiker clamps used where ever possible.
                Brand new Nippondenso R134a swashplate compressor, AC should be top notch.
                Ready to receive the ceramic coated exhaust manifold
                A quick flip upside down to prepare the mating surfaces for the oil pan.
                New upper oil pan installed
                New lower oil pan installed
                and a valve cover!
                Upper intake manifold, dipstick rube
                Throttle body heater plates, again with Oetiker clamps to keep it tidy
                Throttle body installed
                All three drive belts
                Ignition wires with guide tray, rail and ceramic coated heatshield
                New cover plate
                New idle control valve (Barf at the cost of this little shit) and VIN tag.
                Awaiting a few more small items to arrive from the dealer tomorrow, as of now its essentially ready to drop in the car. Tomorrow is the big day.
                • mike.bmw
                  • Dec 2015
                  • 1751
                  #1088
                  Beast mode unlocked. Drool-worthy work as usual.
                  • econti
                    • May 2014
                    • 1093
                    #1089
                    I suppose it's not possible to get some brochure spec photos of it? They are beautiful engines once clean like that.
                    • Jordan
                      • 12907
                      #1090
                      If there is something in particular you want to see by all means let me know, happy to take more pictures.
                      • Conrad311
                        • Oct 2009
                        • 368
                        #1091
                        I’ll be the one to say it.. The cyl 2 header is killing me!
                        Sucks when things like that happen, but unavoidable sometimes. But that is one beautiful engine for a beautiful car! Almost too good to even run it! You should sell it to the BMW museum in Munich.. Probably better than what they have! Zero minute, zero mile car!
                        I’d love to see it in person next time I drive out from Austin!
                        "In God we trust. All others must bring data." -W. E. Deming
                        /// 1987 325is /// Project Thread
                        Past: 87 is, 88ix, 88 i, 87 ic, 89 ix, 17 others.
                        • Jordan
                          • 12907
                          #1092
                          Yeah, that scuff on the cylinder #2 runner is unfortunate. I had the exhaust stood up in a corner of the garage with that runner touching the drywall and it left the mark. After taking the photo I noted it looks much worse in pictures than it does to the eye but took some 0000 steel wool and buffed the spot, reducing the appearance easily 50% or better. That is fine enough as I'm not waiting weeks for it to be recoated, and once installed you cannot see that spot.
                          Lots of progress today, and my back is reminding me I'm becoming an old man...
                          I had a difficult time finding a clear photo that showed the proper routing of the crankshaft and camshaft sensors, so after I got them figured out I took one. Both sensors new Genuine BMW,
                          Swapped out the 3x Worldpac Conti belts (because they said Made in China on them) for 3x Genuine BMW belts. Two are Contis (Made in Germany) one is an optibelt, which is also Made in Germany. I've not seen that brand state side before, but as said its Genuine BMW and well its on there now.
                          Lightened M20b25 single mass flywheel with 8 bolts loctited and ready to go in and be torqued to spec. Also installed a new pilot bearing at this time.
                          Getting ready to install the new M20b25 clutch kit. If E30's are Gods Chariot, than my broken G240 input shaft is The Lords Centering Tool. I've broken 2 G240's and as luck would have it they were both different sizes and I saved both input shafts for this purpose. The plastic tools that often come with clutch kits suck.
                          Preparing the engine bay to receive its heart
                          Up she goes
                          Almost there
                          A little nerve racking doing this solo, going down a little bit then checking all around for clearance before proceeding. Mustn't scratch anything! Here she is, in her new forever home
                          Now its time to get the transmission installed. New release fork with euro 323i throw out bearing
                          New debris shield with all of the needed hardware
                          Dust shield installed, while I lay there looking at the transmission I need to sling up in there in a minute.
                          I bear hugged the transmission and rolled it over up onto my chest before bench pressing it up into place. Slick as shit it slid into place with zero fuss first go. It don't always be like that, but sometimes it do.
                          Getting the shifter linkage and driveshaft in place.
                          From the front
                          and final task for the evening, installing the forward section of the exhaust with the new hanger
                          • 0-60 freak
                            • Jun 2015
                            • 511
                            #1093
                            Looks fantastic!! Sent from my SM-N975U using Tapatalk
                            Current Cars:
                            2016 PORSCHE GT3 RS
                            2017 FERRARI 488GTB
                            2018 RAPTOR CREW CAB
                            1991 318is SLICKTOP H&R SPRING SEMA CAR
                            1991 318IS SLICKTOP STERLING SILVER
                            1990 325ic BRONZIT/AUTO :)
                            1989 E30 M3 (SOLD AWAITING SHIPPING)
                            On Order:
                            2018 DODGE DEMON
                            Searching for:
                            CLEAN E30'S
                            S54 DRIVETRAIN
                            E30 DASH
                            E30 PARTS
                            • Shu
                              • Nov 2015
                              • 132
                              #1094
                              Absolutely amazing.
                              Zelig the Zinno • 300k and counting
                              http://instagram.com/zelig.the.zinno
                              • Digitalwave
                                is a poseur
                                • 6280
                                #1095
                                Kind of sad this project will be coming to an end soon.
                                RISING EDGE
