Well you said it, you got yourself in a pinch. Hurry and crank some out!!!!!
★★★★Project Tracy★★★★ Wideband AFR - New product -ready to ship
turk@gutenparts.com
Originally posted by JandersonProperly placed zip ties will hold bridges together.
Isn't that gauge driven by a PWM driver? Also, how are you planning on attacking the later style cluster that integrate the SI board vs. the older model clusters that can simply have a jumper put in place and still work sans SI board? From what I have found, to be able to remove the board from the later model clusters, you would need to replace all of the drivers with an aftermarket device (the tach circuit I know for a fact will not work on a later model cluster without the driver that is on the SI board).My 2.9L Build!
Originally posted by Ernest HemingwayThere are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.
Originally posted by bender View Postthought the two independent coils that control the meter were a little wacky. whats the easy solution for this?
There are three basic pieces: a magnet and pointer attached to a freely rotating axle, and two coils, each oriented at a right angle with respect to the other. The only moving part in this meter is the axle assembly. The magnet will tend to align itself with the vector sum of H fields of each coil, where H is the magnetic field strength vector. If, for instance, a current passes through the cosine coil the magnet will align its magnetic axis with the coil's H field. Similarly, a current in the sine coil. If currents are applied simultaneously to both sine and cosine coils, the magnet will turn to the direction of the vector sum of the two H fields. H is proportional to the voltage applied to a coil. Therefore, by varying both the polarity and magnitude of the coil voltages the axle assembly can be made to rotate a full 360 degrees.
Originally posted by PiercedE30 View PostIsn't that gauge driven by a PWM driver?
Originally posted by PiercedE30 View PostAlso, how are you planning on attacking the later style cluster that integrate the SI board vs. the older model clusters that can simply have a jumper put in place and still work sans SI board?Originally posted by Matt-Bhey does anyone know anyone who gets upset and makes electronics?
Originally posted by AlpineEdirty View Postcould you make a Formula one type rev indicator(shift light) using the oil service indicator light?
It's best to never even look at the tachometer when shifting. Learn the sound of your motor first, and you are golden.
Oil pressure, temp, boost, volt, AFR, ect...That's something that is useful to know.
If I mess with the Si lights, it will be something useful. See what I am saying?Last edited by george graves; 07-03-2008, 01:39 AM.Originally posted by Matt-Bhey does anyone know anyone who gets upset and makes electronics?
I finished the design for a prototype of the hazard/defrost "bar graph" led boost gauge tonight. And I'm testing it with a numeric display soon. It seems in a rush to order parts, I spec'ed the wrong part from my vendor. So, I'm looking forward to more parts coming in as soon as my paypal account recovers - I've been on vacation for the last 2 weeks. Sorry for the delay.Originally posted by Matt-Bhey does anyone know anyone who gets upset and makes electronics?
Sweet deal.
So George whats your take on the vac + boost gauge? Reading through tuning manuals and stuff, tuning for max vacuum is a very good indicator of how well the motor is running. The Vac addition might be a deciding factor for someone like me who tunes their own car.
Jon, i know SI indicator sucks pretty hard. If you pull the board out, you can see that the display is just that, it has nothing to do with the circuitry of the board or how it functions. Just cut it off and leave the board in there!! I did and everything still works fine.-Chris
Ely (rs4pro3) saw the work I did with the gauges and asked if I could make him an replica of an Alpina full face gauge. So I did.
The colors might need tweaking, it depends on what it is being printed with. Ideally, a color laser or better.
Here is a link to the download(300 dpi). If anyone is interested, they can download them here:
http://www.digitalunderpants.com/ely/300DPI.tif
Enjoy. BTW - You may not use this work for commercial purposes.Originally posted by Matt-Bhey does anyone know anyone who gets upset and makes electronics?
BBY1104
WOW!!
when in production I would take a AFR ratio gauge with numeric readout? if possible, voltmeter gauge,
you sir are an Electronics pimp!!!
keep us updated and what do you expect to charge?
wow I havent checked this thread ina while. Boy was I missing out. I have always wanted to get into electronics like this but have never had the time or the place to start. Awesome work on all these projects... I am very interested in a LOW of them.
as I have said before my dream cluster is...
1: Service lights replaced by sequential shift light
2: mpg meter replaced by amber/black lcd like in the new bmws... the display gives oil temp/press, afr, fuel press, voltage, AIT, ect. with scrollable displays.
3: programable warning lights triggered by values from the lcd.
4: Coolant temp gauge that measures acurately in real units(not blue/middle/red)
... and an 8k tache30sport.net
'15 Porsche GT3 - 7-speed PDK - Daily Driver
'89 325is - m20b25 - 5-speed - Individual
