DTM style trailing arm project.
  • R3VM3UP
    • Jan 2017
    • 170
    This is very cool, I'm looking forward to an update when you have a chance to test it.
    I'm not too familiar with the DTM control arm design, is there a heim joint on the inner pivot point as well that allows for toe adjustment when you adjust the threaded rod at the outer joint?
    • silnc
      • Feb 2015
      • 90
      Originally posted by R3VM3UP
      This is very cool, I'm looking forward to an update when you have a chance to test it. I'm not too familiar with the DTM control arm design, is there a heim joint on the inner pivot point as well that allows for toe adjustment when you adjust the threaded rod at the outer joint?
      Both the camber and toe adjustments are made on the outer. Sent from my Moto G (5) Plus using Tapatalk
      • The Dark Side of Will
        • Jun 2010
        • 2796
        Did you make the bung adjuster yourself or source it?
        • silnc
          • Feb 2015
          • 90
          It's IRP Sent from my Moto G (5) Plus using Tapatalk
          • R3VM3UP
            • Jan 2017
            • 170
            I see that now, makes sense. This seems like a great option. I may give it a shot over the winter. It looks like the heim joints should be easily replaceable too.
            • pazi88
              • Sep 2015
              • 584
              Related to this topic, Magnus Racing Team will have DTM adjustment kits for sale: https://www.facebook.com/pg/magnusra...=page_internal
              No affiliation. Just saying if there is someone interested of those.
                • Jun 2010
                • 2796
                Keep in mind that with the toe adjustment at the outer, the wheel moves forward and back in the wheel house as the toe is adjusted.
                  • Jun 2010
                  • 2796
                  Ahh, found it. Thanks!
                  • hasa
                    • May 2013
                    • 307
                    Double rose joint solution for each side would work better. Nice fabrication!
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      The same movement happens if you are adjusting from the inside as well.
                        • Jun 2010
                        • 2796
                        It moves less when adjusted at the inner.
                        BMW themselves put the toe adjusters at the inner pivots on the E34 M5.
                        • silnc
                          • Feb 2015
                          • 90
                          Made coilovers out of some bilsteins since they're nice and skinny... Just need to paint these arms and install for testing. Sent from my Moto G (5) Plus using Tapatalk
                          • silnc
                            • Feb 2015
                            • 90
                            Started on the install this morning, hopefully be done by the end of the day. Sent from my Moto G (5) Plus using Tapatalk
                            • R3VM3UP
                              • Jan 2017
                              • 170
                              On a trailing arm suspension the wheel will move front to back in the wheel well a bit during normal suspension travel. I don't think that the adjuster at the outer point will make much of an impact on overall position, though I do see how putting it inboard would make it move slightly less. My guess is it was positions on the outer point for easy adjustment in the DTM car.
                              Anyhow, this is looking awesome with the coilovers. Any details on the components you used to assemble those?
                              Edit: looks like maybe just some Bilstein coilovers sleeves?
                              • silnc
                                • Feb 2015
                                • 90
                                On a trailing arm suspension the wheel will move front to back in the wheel well a bit during normal suspension travel. I don't think that the adjuster at the outer point will make much of an impact on overall position, though I do see how putting it inboard would make it move slightly less. My guess is it was positions on the outer point for easy adjustment in the DTM car. Anyhow, this is looking awesome with the coilovers. Any details on the components you used to assemble those? Edit: looks like maybe just some Bilstein coilovers sleeves?
                                Yeah they're Bilstein sleeves, I welded a perch on. Update. Everything fit up really nicely. First drive I noticed an immediate improvement over rear turn response, super snappy. Adjustment is a breeze. I string aligned the toe and used a digital level for the camber. Sitting at approximately -2 right now. Hopefully in the future we can find someone with an alignment rack to help us really dial it in. I'll try and get more pictures soon. So far so good, really love how these turned out. Sent from my Moto G (5) Plus using Tapatalk
