4x100 big brake kit thread
    Hello,
    Wanted to make this thread to see who is using what. Letís keep this thread specific to 4x100
    Please reply with kit information , caliper type, piston quantity and diameter , rotor diameter and thickness etc .
    Also it would be helpful to list what wheels are being used, with or without spacers? Size of the wheel and offset .
    Letís keep this thread as factual and informative as possible.
    Iíll try, today I printed massive lees 300x22mm kit template utilizing wilwood superlite calipers . I went ahead and checked clearance against TireRack Trm 15x8 e30 specific wheels , they clear for the most part but would need 3-5mm spacer to have clearance on the edges of the caliper against the wheel.
    Massive 300x32 kit will require even bigger spacer, probably 15mm to clear.
    a couple different variations available here: https://www.300mm.de/index.php?cPath...l8pqlnev7g4cs7
    cars beep boop
      This one looks interesting , anyone know what they are doing for rotors ?
      https://www.300mm.de/product_info.php?products_id=153
        I have 300x32 Massive floating rotors front and rear.
        6 piston radial mount wilwoods up front
        4 piston wilwoods in the rear.
        25mm e32 master cylinder 34311156643
        modified 944 booster
        Hawk DTC front rotors / Wilwood rears
        the front will fit 15x8's but the radial mount 6 pots are huge and you need a 20mm spacer for 15's and an 8mm spacer of the ARC-8's i"m running now.
        1991 318is S52
        1987 325i Vert
        1991 325i
        2011 e70 X5
        Need Anything E30? -> http://www.gutenparts.com/
          I have IE's Wilwood kit, links included with all the specifics on the kit themselves.
          6 Pot front 4 Pot rear.
          310x22 front
          310x22 rear
          E90 Booster and Master
          http://www.iemotorsport.com/bmw/item/e30bbk310w.html
          http://www.iemotorsport.com/bmw/item/e30310Rm3.html
          I am running them under drilled and filled E38 Style 5's Et23, 225/45R16 no spacers they fit perfectly.
          Euro Delivery Thread///E30 Project Klaus
            On my silver e30 going be using in front 296x25 rotor with mercedes caliper. For 300mm.de 294x22 rotor , adapter spacer and e36 m3 calipers.
              I am running the massive 300x32 kit on all 4 corners, wilwood superlite calipers with AP rotors and PFC pads, 25mm MC, e21 booster. With some slight shaving of the caliper, Kosei K1s fit with no spacer, but I run a 3mm one. The old team dynamic pro race 2 wheels fit without shaving the calipers.
              NASA MidSouth TT Director / GTS2 #018
              Mods: Coastal PS Fluid, 10w40 Oil
              Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
                Very nice, this is pretty much exactly what I plan to run. I really think the Massive kits seem like the best quality BBK setups on the market. Awesome to hear that the K1s fit over this setup. 15s I assume? What width and offset? Are you running the radial mounted calipers?
                  Sorry, should have mentioned. Its the 15x7 K1s, ET25. I have an older kit with the 4 piston superlites (1.62" pistons) instead of the radial calipers.
                    That looks phenomenal. Are those canards something custom or are they something that is available off the shelf?
                    Are you using a manual brake setup? I'm planning to go with one of the Massive dual master manual setups and eventually the same front BBK.
                      They are custom, I made a few sets in case they got destroyed. I am running a 25mm MC with e21 booster. The brakes feel great IMHO.
                        Only thing I don't like about my RS003s; zero BBK fitment.
                        1989 325is Lachssilber - Sold
                        1990 325is Sterlingsilber - Current Project
                        September 2018 Car of the Month: Zeemz
                        Youtube Track & Autocross Videos
                          Has anyone had fitment issues with the IE front kit? Like pistons on 1 side of the caliper, protruding further on one side than the other side? Or the floating rotor hitting the outer tie rod?
                          http://www.iemotorsport.com/bmw/item/e30bbk295.html
                          This set up, specifically.....?
                          @IRON-E30 aka Edwin:D
                            Mine will fit, with spacers, I just didn't want mine spaced out so much:)
                              Not sure about that kit, I have the 16", and I did have problems with it hitting the E36 tierods from my rack swap. Turns out the off brand that Rackdoc sent me was the issue.
                              I put a set of Lemforders on there and that cleared up the issue.
