R3VLimited Forums
Go Back   R3VLimited Forums > General Forums > Track & AutoX
Reply
Thread Tools
Old 10-15-2014, 01:14 AM   #1
epluribusunum
E30 Pedal Mount Boosterless Bracket for Wilwood / Tilton Pedal Assembly
https://sites.google.com/site/bmwfab...30-pedal-mount
Enhance the performance of your E30 brakes by installing a Wilwood or Tilton Manual Brake & Clutch Pedal assembly.
A must if you do a custom engine swap ( such as the popular E30 M60 V8 swap ), turn your E30 into a racer, upgrade to a big brake kit or convert to a 5 lug swap with E36 M3 brakes.
- The entire assembly, including pedals, master cylinders and pedal box is approx. 8lbs. lighter than the factory pedals, master cylinder and brake booster.
- The mass of the assembly is closer to the carís center of gravity.
- Master cylinders are positioned inside the firewall, away from engine heat.
- Compact design allows for more engine bay room for your custom E30 engine swap.
- Pedals and pedal pads are of special adjustable design that allows fine-tuning of the pedal location and clearance.
- Enhanced control over brake bias for various driving conditions.
- Improved pedal feel gives driver great feedback for enhanced car control.
- Computer designed, FEA tested and CNC machined to ensure for a stiff component structure.
Important notes:
- This pedal mount does not work with airbag steering columns.
In order to use this mount in an airbag car, a non-airbag steering column must be installed instead.
Welded pedal mounts available! Kit includes hardware!
$169 plus $12.50 Priority Mail Shipping via USPS shipping.
International shipping also available.
Prices are subject to change due to material and labor costs.
Please contact realm3bimmer@yahoo.com for information on payment, shipping and instruction manuals .
Thank you!
Updated 10.15.2014
epluribusunum is offline   Reply With Quote
Old 10-17-2014, 05:55 AM   #2
Massive Lee
Massive Lee's Avatar
Hey buddy. I suggest you read this about your "original" work.
http://www.e30tech.com/forum/showthr...25#post1385425
Thanks
Lee
__________________
massivebrakes.com
Massive Lee is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.10
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Copyright 2004 - 2020 R3VLimited LLC
