What serpentine belt for deleted ps?
  • 325issguy
    • Dec 2005
    • 261
    Hey guys,
    I have been searching everywhere and cannot find what belt you all use when you delete your power steering pumps. I am running a m52 if that makes a difference.
    -Chris
  • Dominic49
    • Feb 2007
    • 1373
    56.1 inch
    • lifeiskaos
      • 1709
      Mine:
      6PK1400
      • rThor432
        • Feb 2007
        • 3907
        I used a stock R53 Mini Cooper S belt. I didn't have the aux pulley on the alternator, just like in the picture above. It was perfect. Thought I'd mention that as it was an off-the-shelf item (not that most serp belt lengths won't be, it's just easier to deal with some parts guys when you've got a Make and Model).
        • bykerboy
          • 152
          Originally posted by Dominic49
          56.1 inch
          Yup, this is what I used too. You can get one at any auto parts store.
          • bejbis
            • Dec 2008
            • 596
            Just ordered this belt and it does work. Part # is 11287520199 and the #'s on the belt are 6KX1388.
            -Dan
            • SamE30e
              • Sep 2007
              • 4319
              I think the goodyear part number would be a 4060561 or 4060560
              Or 560k6
              or 561k6
              You get the idea.
              1985 325e 2.8 Turbo VEMS
              • rosphill
                • Jun 2007
                • 187
                M50 serpentine belt
                What size serpentine belt would you run on an M50 if you are only running an alternator and power steering pump (NO A/C compressor) ?
                Thanks
                Originally Posted by Blunt
                I've done this so much I have a toenail on my dick.
                • BenM
                  • 2184
                  Thanks
                  A/C compressor is on a separate belt. Assuming you are running all the regular accessories (alt, PS, water pump) then you would just need a regular sized belt (6PK1460 IIRC)
                  Originally posted by BillBrasky
                  E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
                  1991 318i Alpine II - S50/5-lug swapped - track car
                  1989 325i Cirrusblau - Daily
                  1970 2500 - Malaga over Grey Cloth
                  2012 F350 6.7PSD
                  • surebimmer
                    • Jan 2004
                    • 978
                    Thanks
                    A normal one. A/C has it's own belt.
                    • rosphill
                      • Jun 2007
                      • 187
                      Ok very good that's what I thought just wanted to be sure. Trying to not buy any of the wrong parts or anything that won't work for my application on the M50 swap. Thanks so much for the prompt reply! :D
                      • mazur
                        • Jan 2006
                        • 731
                        To add data to the thread...
                        I kept my idler pulley and a 56.25in belt is the perfect size.
                        Part#'s
                        K060557
                        6PK1415
                        • matt
                          • 3732
                          Originally posted by lifeiskaos
                          Mine:
                          6PK1400
                          Is that an 850 alternator?
                          • jizo
                            • 1191
                            Am i missing something?? I used the Mini cooper s belt # and it comes up to be 60 inches.
                            Went to pep boys and told him i need a 56.1 inch serp.belt and still its too long.
                            We measured the whole length of where the belt would go with a tape mesure and we got 40.75 inches. WTF!!!??? What am i doing wrong?
                            • blackhawkimpact
                              • 2415
                              Probably routing the belt wrong
