i connected everything and once i connected the ecu to the harness my SI board lights oil pressure light and brake lining light are on and fuel pump is not turning on.
the car cranks but its not receiving fuel the harness adapter i made is wired up exactly how the diagram shows for the square to round c101 plug.
now where do i start could it be a fuse a relay or what causing my warning lights to stay on even with the key out of the ignition when the harness is plugged into the ecu.
