i'm really interested in doing this conversion cuz i can get the parts cheap, but i wanted to know the specs on the calipers and rotors, to see if they r that much better. plus i wanted to know what was involved in the install, what needs to be modified and what not??? thanks
all info on rx-7 calipers+corrado brakes
INSTAGRAM: @UNDR8D_EMPIRE
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Tags: None -
I Want Some Too!Check out Undr8d Empire on Facebook: www.facebook.com/Undr8dEmpireLlc
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
Why??? With a bit of additional cooling for the front rotors (brake ducts) and appropriate pads the OE setup is very well balanced and more than enough, even for full-up race E30's.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
Current Cars2014 M235i2009 R56 Cooper S1998 M31997 M3Comment
I developed the setup because I was tired of burning through a set of front pads in a weekend, and I wanted the pedal to feel the same lap after lap.
I find it funny that you kids on this board can do M/S50 swaps, turbos, sticky tires, suspension, etc, but when someone wants to upgrade the brakes on an E30, the whole "good pads and fluid are all you need" bullshit comes out.Last edited by CBi; 04-29-2007, 03:48 AM.Comment
Why not get 4 piston calipers and 280mm rotors for marginally more than rebuilding stock? I dunno guys, but with the "right shit" the brakes were still cooking on a very brake intensive track when I was turning the screws. Yes I had cooling, yes I had proper fluid, and yes I had proper pads.
Expect the RX-7 mounting brackets within the next few weeks.Comment
Expect a full writeup as soon as the brackets are finished (working on protos now, need to machine up the final pieces out of 304 stainless)Comment
TOMEK rocks!!!! :bow:Check out Undr8d Empire on Facebook: www.facebook.com/Undr8dEmpireLlc
