Engine
-S50B30US engine, runs well but needs valve stem seals $sold
-S52B32 engine good $sold
-S52B32 turbo 8.5:1 compression T04E ball bearing, all manifolds, E34 pan, E36 mounts, plumbing OBD1 miller WAR computer with base tune, 60lb injectors, exhaust system. UUC kevlar clutch, flywheel, everything to drop in to an E30 with your choice of transmission $4,500
-M20B25 cylinder head 885 casting good bare $280
-M20B25 cylinder head complete 885 casting $340
-M50/52/S50/52 single vanos head not cracked $300
-M54/M52Tu head good $250
Transmission
-S5D 310Z ZF 5 speed box good $sold
-S5S 250G Getrag 5 speed good $360
-S5S 260G Getrag 5 speed box (260/5 w/o reference sensor holes w/ alum shifter) $sold
-Getrag 242/232 2002 E10 box good $300
-E53 X5 3.0i 5 speed manual transmission and transfer case $600
-M42 flywheel, dual mass $80
-M10B18 flywheel single mass $60
-95 M3 S50B30 flywheel and near new clutch $sold
Driveline
-E30 small guibo Getrag 260 RWD drive shaf (CSB may not be good) $180
-E10 4 speed manual drive shaft $140
-E36 318i manual drive shaft $100
-E46 M3 6 speed drive shaft $140
-E30 iX front drive shaft good splines $SOLD
-E36 328i / M3 ZF 4 bolt swap drive shaft for swaps $sold
-E30 ABS 6 cylinder stub axle new $60
-E90 stub axle 328i/325i new $50
-E53 front right and left new stub axles $100 pair
-E36 325i/323i stub axle (new) $50
-E34 stub axle 525i $30 (2 avail)
Shifter:
-E30 M42 carrier and selector $40
-E36 G250 (318 325 323) selector and carrier $50
-E34 525i M20 (G260/5) carrier and selector $45
Differential:
-3.91 Viscous Coupling rear differential
-4.10 medium case clutch LSD
-4.10 Viscous Coupling medium case LSD
-E90 rear wheel drive manual differential $150
-F30 2.81 open differential rear $150
Brake
-E30 Gerling booster and MC $45
-E30 iX booster and MC $165
-E36 525i/530i DSC module $100
-96 M3 front calipers $90 pair
Body
-Front plastic bumper w/ core and shocks, rear plastic bumper w/ core and shocks $550 +freight or pickup
-kidney grilles $25
-headlight grille pair $30
-Startec early tail lights
-Left OEM E30 M3 side skirt
-OEM E30 M3 deck spoiler brilliantrot
-yellow Hella french smiley headlights
-OE early and late tail lights
-late and early fog lights
Electrical
-Motronic 1.0 M20B27 green label 027 DME $70
-Motronic 1.1/1.3 ECUs for M20B25 $80
-Motronic 1.3 ECU for M42 $110
-idle box for M20B27 $30
-ms41.1 DME - EWS deleted, S52 map (WBS DME) $160
Steering
-e30 stock RWD rack with tie rods $100
-E30 set e36 3.2 rack with pressure line and tie rods for drop in $sold
Interior
-Cardinal parcel shelf premium sound holes $80
-cardinal premium sound rear speakers w housings $120
-HVAC panel uncracked $45
-blower motor $100
-gauge cluster parts $5 and up each
-glove box $65
-glove box latch $35
-crack free dash $400
-Husco arm rests
-E30 M3 clusters
-E30 M3 black leather full interior
-6 button and 13 button OBCs
-euro clocks
-Sport evo dead pedals
Suspension:
-e46 left control arm new $60
-e46 right control arm new $60
-pair near new E30 non M non iX control arms with lollipops installed $90
-e90 full front control and thrust arm set (new) $170
Manual bits
-E30 non SRS pedal set $140
-E30 SRS pedal set $155
-E36 pedal set $125
-E36 manual pedal set $140
-e30 5 speed K member $45
-E36 getrag 250 k member $40
new OEM E30 M3 fenders $ask
Transmission
Driveline
Shifter:
Differential:
Brake
Body
-kidney grilles $25
Electrical
Steering
Interior
-blower motor $100
-glove box $65
-Husco arm rests
-E30 M3 clusters
-euro clocks
Suspension:
Manual bits
-E36 pedal set $125
