Leftover Parts from completing an E30 S52 swap and Partial Part Out of S50
All Parts are O.B.O. and don’t include shipping
-Exact shipping costs will be passed to you upon purchase, so I priced items low
-Complete M20 Motor with ECU, MAF, Oil Cooler, Wiring Harness: $500
-190k Runs Absolutely Perfect (bought car to do S52 swap)
-2nd owner
-Extensive Records from 1989
-Timing Belt done at 175K
-Have and extra rear main seal
-S50 Cams w/ trays, lifters, caps, gears ect… $150
-S50 Crank Shaft: $150
-S50 Rods (6) 4 w/ pistons: $150
-S5x/M5x Starter: $30
- (2) S5x/M5x Oil Pans w/ dip stick tubes: $50 each
-S5x/M5x Timing Chain Cover: $10
-S5x/M5x Rear Main Seal Cover: $10
-S5x/M5x Oil Filter Housing: $20
-S5x/M5x A/C Pump Bracket w/ tensioner: $20
-S5x/M5x Timing Chain Tensioner: $10
-S5x/M5x Water pump w/ metal impeller 64K: $20
-OBD I Temp Sensors Gauge and ECU (blue and black): $20 also includes OBDII sensor
-OBD II Stainless Steel Exhaust Manifolds w/ tig welded ports for OBDI: $50
-OBD II Complete Uncut Wiring Harness w/: $100
-O2 Sensors
-Knock Sensors
-Cam Position Sensor
-OBDII ECU 494 w/ EWS: $50
-OBDII ECU 494 w/o EWS: $25 (Another ECU)
-OBD II Intake Manifold w/: $100
-Throttle Body
-MAF
-Fuel Rail
-OBD II Throttle Body: $20
-OBD II Emissions Air Pump: $20
-E36 Jack: $10
-OBD II Unorthodox Racing Under Drive Pulley: $20
-OBD II Fuel Rail: $10
-OBD II Metal Coolant Pipe: $5
-6 17.5 lb/hr (green top injectors): $10
Want all gone Fast!!! Motivated Seller!!!
kevmo707@yahoo.com
-2nd owner
-O2 Sensors
-Knock Sensors
-Throttle Body
-MAF
-Fuel Rail
-E36 Jack: $10
kevmo707@yahoo.com
