WA: Massive amount of E30/E32/E36 parts
  • zvonkorp
    • Aug 2009
    • 27
    All items shipped from Seattle, WA and are in good working condition unless specifically stated otherwise - this means no leaks, cracks, deformities, or anything that would impact normal functions of the item - I throw away anything that's visibly damaged to begin with - lots of parts here so if you're looking for something in particular, hit ctrl+f and search for it
    Prices do not include shipping - there are certain shipping rules for freight items - I will build a crate, secure items inside, take pictures & send to buyer with a shipping quote of buyer's preference or forward air.
    Information on items:
    Drivetrain parts are in good condition with no noises/defects unless specifically stated
    Exterior panels most likely need repaints unless picture says otherwise
    Electrical items are in working condition
    Interior pieces are free of tears/scratches unless picture shows or stated otherwise
    Cooling related items do not have any leaks and are in good condition
    Engines are ready to be plugged in and ran - all engines will need oil & coolant added
    Suspension pieces are not blown
    Brake pieces do not leak or have any defects
    Any pumps or lines or items that contain any kind of fluid do NOT leak
    E32 750il front bumper - $30, no cracks - comes wth all the ducts & grills
    E32 750il driveshaft - great condition $40
    E30 turn signal & wiper switches $15 each
    E30 brake master cylinder $15
    E30 ABS computer $30
    E30 headlight grill - no cracks $15
    E30 center console, black or blue specify - $20
    E30 gauge cluster - 325e, 220k miles - $40
    E30 M50 S50 M52 S52 oil pan - no leaks, just needs a light cleaning - $40
    E30 13 button OBC $15
    E30 glovebox upper cover with light $10
    E30 front grill $25
    E30 driver tail light $20
    E36 M3 front rotors, calipers, hubs/spindles/knuckles (one hub is seized) - $150 for everything, comes with whole set
    E30 Roof handle $5
    E30 front seatbelt latch with sensor and wire $10
    E30 headlight switch $15
    E30 heater control cover $5
    Lots of E30/E32/E36 parts for sale, check my thread: http://r3vlimited.com/board/showthread.php?t=149729
  • zvonkorp
    • Aug 2009
    • 27
    E30 in tank low pressure fuel pump, sending unit, and strainer - $25
    Red rear sidemarker $5
    E30 ignition switch and harness $15
    E30 tail light panel (I have both) $10 each side - no bulbs
    E36 M3 OEM front passenger turn signal $25
    E36 M3 driver foglight with yellow laminx $30
    E36 M3 passenger foglight, slight burning from high watt bulb $25
    E30 rear tail light - mounts to decklid $15
    All kinds of relays for E30's - $5 each (I probably have any you need, please email me and let me know thanks)
    E30 interior door chime $10
    E30 ABS control unit $30
    E30 sunroof motor & harness $20
    E30 glovebox side cover $10
    E36 M3 front struts - slightly damaged bottoms but the springs and struts are in good condition $150 for the pair
    E30 E-brake handle $5
    M50 oil filter housing $20
    E36 AC compressor $20
    E30 power steering pump $20
    E30 aluminum (inline 6 engine) thermostat housing new with box & seals $20
    • Jean
      • 18228
      pm sent
      • zvonkorp
        • Aug 2009
        • 27
        E30 Main relay $10
        E30 speaker balance switch $7
        E30 HVAC switch $10
        E30 window lock switch $5
        E30 rear defrost switch $7
        E30 hazard switch & diode $10
        E30 window switch $7
        E30 interior light $5
        E30 OEM 4 spoke wheel great condition $25
        E30 (M20 inline 6) new thermostat with box $5
        E30 convertible trunk light $15
        E30 sidemarkers $5
        E30 low beams $7 each
        E36 M50 S50 camshaft position sensor $15
        E30 ambient temp sensor $10
        E30 coolant level sensor $10
        E36 ambient temp sensor (brake duct) $10
        • brokenbimmer533
          • 317
          dibs on Mtech 1 wheel. You have pm.
          • Quadrajet
            • Jul 2008
            • 1278
            You have a PM. PM'd about Check Panel, HVAC Panel, Sunroof crank,CC.
            • bzboardz
              • 1096
              how is the condition of the e30 manual sunroof crank? is the black knob still there? pm please
              • zvonkorp
                • Aug 2009
                • 27
                E30 coolant temp sending unit $7
                E30 coolant temp fan switch $7
                E30 altitude sensor $10
                E36 brake fluid level sensor $10
                E30 sunroof motor cover $5
                E30 visor cap $5
                E30/E32 lock knob $2
                E30 armrest knob $2
                E30 hood release handle $10
                E30 interior door handle (please specify which side) $10
                E30 interior door handle surround $5
                E30 overhead check panel $10
                E30 ignition key panel $10
                E30 fusebox lid $10
                E30 OEM C5907 radio $30
                Dinan performance chip for E30 325e/325es D900-2532 $70
                E30 passenger tan seat $30
                E30 rear deck $15
                • zvonkorp
                  • Aug 2009
                  • 27
                  E30 passenger & driver interior door panel tan/blue (specify color) $15 each
                  E30 trunk carpet $10
                  E30 coupe door seal (specify which side you need please) $10
                  E36 M50/S50/M52/S52 engine mounts $20 pair
                  E30 trunk seal $10
                  Momo harness latch $10
                  E30 OEM rear bilstein shocks $15
                  E30 heater control switch $10
                  E28 passenger mirror (I think...) $15
                  E30 windshield wiper pump $10
                  E30 wiper tanks!!! $10 each
                  E30 manual transmission insulation $5
                  E30 blue rear carpet $15 for the pair
                  E30 brake reservoir with sensor & cap $20
                  E36 horn $10
                  E30 front ashtray $10
                  E30 speaker cover panels - tan, blue, black - specify which color & side - $10 each
                  E30 emergency brake handle black - $10
                  E30 tan armrests/door handles $10 (specify side please)
                  BMW M70 V12 intake manifold engine cover $10
                  • zvonkorp
                    • Aug 2009
                    • 27
                    Manual sunroof crank is spoken for, sorry
                    • vpilarrt
                      • Jun 2006
                      • 2096
                      You have a pic of the E32 Cruise Module where the cable hooks to the throttle arm?
                      • zvonkorp
                        • Aug 2009
                        • 27
                        BMW 2002 fusebox $10
                        E32 central window control switch $10
                        Assorted lighters (specify please) $5
                        E32 mirror control switch $5
                        E32 eat control switch covers $5
                        E32 750il onboard computer $20
                        E32 750il transmission computer $40
                        E30 idle air control valve $20
                        E30 overhead headrest cover & visor rack $20 (specify color please)
                        E30 tan rear deck with speakers $20
                        E36 brake reservoir, cap, and sender $15
                        E36 power steering lines $20
                        E36 radiator cooling fan $20
                        E36 engine cooling fan & clutch $25
                        E30 Bosch Motronic ECU for 325e/325es M20 2.7 engine - $40
                        E36 M3 S52 OBD2 3.2 OEM exhaust manifold front & rear $20 pair
                        COMPLETE E30 SEATBELT (or seat-belt) - belts and latches front and rear for a coupe - $30 all in good condition
                        E36 Air conditioning lines/bracket/compressor the works - everything in a box - $40 takes the whole thing everything works
                        E30 coupe grey sunroof / moonroof panel & rear deflector $30 - needs paint... no rust
                        E30 rear window molding/trim piece, grey $10 (specify which side you need in your email)
                        E30 toolkit trays - most of these are missing tools I have a bunch, but the trays are ok and can be made to look great with little work, if you need one they're $5
                        E30 front driveshaft half $10
                        E30 interior door bottom trim $5 (specify side)
                        E30 blue recaro driver side - tear in headrest (replace) and small hole in under-knee bolster $40
                        E30 driver & passenger powered rearview mirrors - they need paint, specify side - they all work - $10 each
                        E36 hellrot (red) headlight eyelids $20 pair
                        E30 rear center console (no ashtray) specify color blue or black $15
                        E30 coolant expansion tank - $25
                        • tonytony
                          Knee deep in poopie
                          • Jan 2004
                          • 3498
                          Those are obd1 cast iron manifolds btw and the e30 driveshaft is the rear have, also the e30 sport seat is a passenger side, just so you know;)
                          • vtman05
                            • 86
                            pm'd
                            • ZenkiOwns
                              • Jul 2009
                              • 496
                              E30 HVAC buttons and Hazard/Turn signal RELAY shipped to 29406?
