I have a whole bunch of extra E30 parts that need to be sold.
I'm located in Gainesville; GA. Shipping can be arranged for items at buyer’s expense.
A tracking number and shipping insurance will be provided.
These parts are from an 88' and 89' 325is. All parts were in working order when they were taken off of my two part-out cars.
Here are all the E30 Parts:
-New Kolbenschmmidt Main Bearing Set M20B25 Early model Engines $60
(The Ref. number is: 11 21 1 265 459) The box and packaging has been opened but the bearings wear never installed. I was unaware that there was a difference between the early model m20b25 and the later model m20b25.
-M20B25 Block $100
(I have all the hardware for the block including the intermediate shaft, main seals, and more. Cylinder walls look good.)
-M20 2.5L Crank $100
(In good condition, ready to be shipped)
-Oil Pump (Good Condition) $50
-Starter (good condition) $50
http://i198.photobucket.com/albums/a...Picture042.jpg
http://i198.photobucket.com/albums/a...Picture044.jpg
http://i198.photobucket.com/albums/a...Picture043.jpg
-Throttle Body w/ throttle positioning sensor (In Good Condition) $30
(This throttle body was off an 1989 325is with an m20b25 2.5L)
http://i198.photobucket.com/albums/a...cture005-6.jpg
http://i198.photobucket.com/albums/a...cture004-6.jpg
-Injectors $25
[Ref. # 0250150715]
http://picasaweb.google.com/lh/photo...eat=directlink
-Fuel Rail and Fuel Regulator $25
-Fuel Injector Harness w/ plastic covering $25
(The Harness is off a 1989 325is with the m20b25 2.5L engine. This harness also comes with the metal bracket and plastic cover for the injector connectors.)
http://i198.photobucket.com/albums/a...cture007-5.jpg
-Spark Plug Wires $30
(This spark plug wire set is numbered 1-6 and comes with coil wire + pulse sensor.)
-3 Spark Plug Wire Covers $14ea.
(All covers are in good condition. Snap in and hold wires with no problems.)
-Gas Tank off 1989 325is $100
(In great condition, No rust)
http://i198.photobucket.com/albums/a...Picture009.jpg
http://i198.photobucket.com/albums/a...Picture015.jpg
http://i198.photobucket.com/albums/a...Picture020.jpg
-Bronzit Gas Tank Cap Flap $15
(Paint is in great shape)
-2 Ac Pumps $45ea.
(Both were in great working condition last time they were on my E30s. The first Ac pump is a Seiko Seiki pump with the Ref. #6452 1386 464. The other Pump is a Denso with the Ref. #64 25 1 386 256.)
Seiko:
Denso:
- AC Condenser w/ Aux Fan $40
(Both the High and Low Speeds worked on Aux Fan)
http://i198.photobucket.com/albums/a...e/DSCN3760.jpg
-AC Receiver/Drier w/ Low-pressure switch, High-pressure switch $10
http://i198.photobucket.com/albums/a...Picture153.jpg
http://i198.photobucket.com/albums/a...Picture152.jpg
-Fan Blade with Clutch $30
(Fan Blade and Clutch are in good working order and did not make any noises.)
http://i198.photobucket.com/albums/a...e/DSCN4219.jpg
http://i198.photobucket.com/albums/a...e/DSCN4221.jpg
-Vibration Damper $25
(Teeth are in good shape)
-Pulley $15
[Ref. # 11231280958]
http://picasaweb.google.com/lh/photo/gK4oqQ5sgF8-yZhLcEHPlg?feat=directlink
http://picasaweb.google.com/lh/photo/9F1PoNQHSA238BqNz_sB-w?feat=directlink
-Power Steering Pulley $15
http://picasaweb.google.com/lh/photo/KcPgs8Ib5bidw0W0GmSs0Q?feat=directlink
-Passenger Side Trailing Arm w/ Axle $100
(In great shape, axle boots are not torn. Also comes with hub bearing assembly.)
-2 Stock Rear Sway Bars $20ea.
- Stock Front Sway Bar 19mm $30
-Front Sub Frame $45
(Off an 1989 325is Coupe)
-Power Steering Rack $55
(Had no leaks or noises)
-Steering Column$45
[Ref. #11534100]
-Steering Linkage $25
-2 Clutch + Brake Pedal Assemblies $25ea.
-M20B25 Block $100
-Injectors $25
[Ref. # 0250150715]
-2 Ac Pumps $45ea.
Seiko:
Denso:
-Pulley $15
-Steering Column$45
[Ref. #11534100]
