I'm located in Gainesville; GA. Shipping can be arranged for items at buyer’s expense. Tracking Number will be provided if shipping is arranged.
These parts are from an 88' and 89' 325is. All parts were in working order when they were taken off of my two part-out cars.
UPDATED: 3/24/10
Here is my most recently updated E30 parts list with pictures:
-M20B25 Block $100
(I have all the hardware for the block including the intermediate shaft, main seals, and more. Cylinder walls look good.)
-M20 2.5L Crank $90
(In good condition, ready to be shipped)
-Oil Pump (Good Condition) $50
-2.5L “I” Intake Manifold (great condition and ready for paint) $45
-2.5L “I” Valve Cover (good condition and ready for paint) $25
-Fuel Rail $12
-Bronzit Gas Tank Cap Flap $12
(Paint is in great shape)
-AFM Boot (In Great Shape, No Cracks, Rips, or Tears) $15
-Brake Booster to Throttle Body Vacuum Hose (Great Condition) $20
-2 Power Steering Hoses
-Coolant Reservoir (In Great Condition) $25
-2 Ac Pumps $40ea.
(Both were in great working condition last time they were on my E30s. The first Ac pump is a Seiko Seiki pump with the Ref. #6452 1386 464. The other Pump is a Denso with the Ref. #64 25 1 386 256.)
Seiko:
Denso:
-AC Receiver/Drier w/ Low-pressure switch, High-pressure switch $10
-Vibration Damper $15
(Teeth are in good shape)
-Pulley $13
[Ref. # 11231280958]
-Power Steering Pulley $15
-Tokico Rear Gas Shock (In good Condition, still has a lot of recoil. Part #HE2756) $25
-325is Strut Housings $40
-Driver Side Trailing Arm w/ Axle & Hub/Bearing $100
(In great Condition, Axle is in like new condition & bearing has less than 10K mi. on it. The bushings have been taken out and are ready for new ones to be put in.)
-Chassis Crossmember (Goes behind Transmission) $15
-2 Stock Rear Sway Bars $15ea.
- Stock Front Sway Bar $20
-Clutch Master Cylinder $20
-2 ABS Computers $25ea.
-E Brake Lever $15
(In good working order)
- E-Brake Boot with Handle (Good Condition) $15
-Rear Brake Light Under Rear Windshield. (3rd Brake Light Off of an 1989, Good Condition) $12
-Engine Bay Blower Cover (In Great Shape) $15
- Heat Insulation Tunnel Bottom $20
(Heat shield for driveshaft #1 on Real OEM’s “Heat Insulation” diagram: http://www.realoem.com/bmw/showparts...34&hg=51&fg=70 )
-Heat Insulation Piece $12
(Goes directly behind the heat insulation piece above, for the rear part of the drive shaft)
-Muffler Hanger Bracket $8
-Exhaust Hanger Bracket $10
-2 Center Caps for the bottle cap style rims $10
-Bronzit Driver Side Door w/ working Power Window $85
(Paint is in great shape and window motor and window worked great)
-Passenger Side 2D Coupe Door Window $20
(In great shape, No cracks or scratches)
-2 Door Dingers $5ea.
-Engine Hood Joint $15
-Hood Support $10
-Pair of Hood Notches $8
UPDATED: 3/24/10
-M20B25 Block $100
-M20 2.5L Crank $90
-Fuel Rail $12
-2 Ac Pumps $40ea.
Seiko:
Denso:
-Pulley $13
-E Brake Lever $15
-Hood Support $10
