FS: Solid M20 Motor & Trans mounts.
  • InNeedOfBoost
    • Aug 2012
    • 512
    #406
    Just installed the trans mounts today. I have a question, how bad are the vibrations with anyone else's experiences?
    Mine is vibrating like crazy! I've had poly mounts in other cars and felt a difference in vibrations, but not like this.
    1991 318is - Daily/weekend track car.
    An on-ramp is a terrible thing to waste...
    • FLG
      • Sep 2011
      • 3165
      #407
      Generally the combination solid motor and tranny mounts will transfer much more harmonics. Check if its exhaust related, sounds funny but i had BAD vibration with solid motor mounts and poly trans mounts, turned out to be the exhaust was a bit loose and causing it.
      Also make sure your guibo, center support bushing, and u-joints are in good shape.
      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
      • MonkeyMadness
        • 3251
        #408
        We just mounted a set of tranns and motor mounts on a 3.2 turbo we have here and have very little "outstanding" vibrations.
        Check your guibo and shaft bearing. Remeber these mounts are solid and don't display any sag like rubber or poly (yes poly sag over time)
        What this means is if your bearing and guibo have "warn" in with rubber or poly. Then you transfer to solid they are now in a position they have not been in or "warn into" this may result in unforseen vibration on a setup that maybe relatively new.
        • InNeedOfBoost
          • Aug 2012
          • 512
          #409
          Gotcha...it may be the guibo then like you mentioned. I'll check it again.
          Possibly the exhaust too...theres a hanger attached to the trans brace. O_o
          • FLG
            • Sep 2011
            • 3165
            #410
            Try revving and see if it shakes the car, that was when i realized the vibration was exhaust not engine or transmission.
            • phenryiv1
              • Jul 2009
              • 3246
              #411
              My experience:
              I swapped in an M20B25 in place of the stock M20B27 in my '87 using Condor motor/trans mounts. Overall, it feels great without being harsh. I am running this car in rallycross events and even in our bumpy conditions and with me running nearly straight exhaust (no cat, all 2.5" piping) I would say that the majority of the transferred vibrations are quite tolerable.
              Compared to other cars (including other dedicated track cars at our events) and with the stock e30 vibrations as a 3 or 4 on a scale of 1-10, the Condor solid mounts only added 1-2 "points" in the 1-10 scale.
              Patrick Henry
              • Nsquared97
                • 1656
                #412
                Had this happen to me last weekend, decided it was definitely time to upgrade. Set of M20 trans and motor mounts ordered.
                • silence
                  • Jun 2007
                  • 1824
                  #413
                  Ouch!
                  i have a video of it happening to me at an autox... i will ship ASAP.
                  • OGT's e30
                    • Nov 2012
                    • 96
                    #414
                    Just purchased motor mounts, tranny mounts and offset cabs for my Betty :D
                    Ty Carlos
                    • silence
                      • Jun 2007
                      • 1824
                      #415
                      Ty Carlos
                      Anytime Orlin!
                      Thanks for your order.
                      • vertvertvert
                        • May 2012
                        • 194
                        #416
                        I'm interested in possibably picking up a combo deal either...the cruiser or the spec, but I don't need the off set lower control arm bushings because I'm going with THR eyeballs. Pm me with a combo deal?
                        Thanks.
                        • silence
                          • Jun 2007
                          • 1824
                          #417
                          Thanks.
                          Checkout the Blackbird combo, it doesnt include the CABS. :)
                          • Nsquared97
                            • 1656
                            #418
                            Got my set today, thanks!
                            • silence
                              • Jun 2007
                              • 1824
                              #419
                              Glad you got them :)
                              • silence
                                • Jun 2007
                                • 1824
                                #420
                                All our mounts and bushings are In stock and ready to ship.
                                We also have a preorder on some new T-shirts. Check them out.
