95 M3 ZF 5 speed - partial swap
  • Pzary3233
    • Mar 2006
    • 39
    SOLD
    I've got what looks to be a very low mileage partial ZF transmission and several pars needed for the swap. The transmission shifts beautifully, it is clean inside and out.
    It comes with the following with 200 miles or less of use:
    Crossmember (original to the car) with new mounts
    Guibo and new bolts
    slave cyl
    UUC hyd. line
    Flywheel, Clutch, Pressure Plate
    Throwout bearing, fork, etc.
    Driveshaft (rebuilt and balanced).
    This is everything needed to swap a ZF transmission into a non ZF equipped car or a great start to swapping out your autotragic!
    I'm looking for an LS1 T56 and would trade for one.
  • Pzary3233
    • Mar 2006
    • 39
    PICTURES!
    Also a price drop!
    These pictures are STRAIGHT out of the car, nothing had been cleaned.
    Shifter is w UUC Adj Short Shifter but is not the full kit.
    Clutch PP and flywheel is OEM BMW found here: http://www.pelicanparts.com/cgi-bin/...ne%20(1995)%20 for a lot less than I paid for it!
    Driveshaft was rebuilt in 02 then sat in the car has less than 200 miles on it. (has tag on it)
    Transmission seems great - see pictures
    • Pzary3233
      • Mar 2006
      • 39
      Shifter lever it's self has sold, so the price is now $600
      • NC325iC
        • Mar 2004
        • 6565
        what are the ratios of this trans? is 5th 1:1?
        if i swapped this behind an m20 id need to have a custom cross member and shift linkage correct?
        also with a 1:1 5th gear a 3.25:1 or a 3.46:1 would be best right?
        would m20 fly and clutch work?
        • Pzary3233
          • Mar 2006
          • 39
          PM sent,
          But yes it is a 1:1 5th gear.
          As for the rear diff ratio, that is up to and your application.
          • Pzary3233
            • Mar 2006
            • 39
            Boss man says I need to get it out of the shop... So Someone buy this stuff!
            • Pzary3233
              • Mar 2006
              • 39
              Sold!
