Hey all,
I recently swapped a m20 with a broken timing belt out for a friend so Ive got some extra parts lying around now. Posted with each part is what Id like to try to get for each part, but just make me an offer and we will try to work something out. If youd like more than one part, I could probably cut you a deal since it makes my work easier (especially the bottom end). All bolts and fasteners can be included with the parts so just let me know what you need.
Id like to sell the parts locally, especially the heavy ones, but have no problem shipping the smaller ones.....buyer pays exact shipping costs.
The bottom end is still in great condition with minimal damage to one piston from hitting the valve. The engine had 220k on it but had good compression in all cylinders and did not smoke.
If youd like to come check out the parts or would like more photos/questions or comments, just PM me.
Thanks!!
Jeff
1. 885 bent valve from digesting a bolt - $70
2. 885 bent valve and broken rocker from broken timing belt - $85
3. 525i oil pan - $50
4. Oil pump - $30
5. Block - $80
6. Crank - $70
7. Pistons -$40
8. Intake - $35
9. Throttle body - $15
10. Fuel rail - $10
11. Injectors - $40
12. AC compressor rebuilt 30k ago -SOLD!
13. AC compressor - $25
14. Fan and clutch - SOLD!
15. Oil cooler adapter - SOLD!
16. Almost new AC drier - $5
17. AC condenser - SOLD!
18. AC bracket 1 -$5
19. AC bracket 2 - SOLD!
20. Thermostat housing - $8
21. Water pump - $10
22. Crank dampner - $15
23. Crank pulley - $8
24. Water pump pulley - $8
25. Power Steering Pump - $30
26. Exhaust manifolds - $16
27. Timing belt cover - $10
28. Auto Transmission ZF4Hp22 - $80
29. Cylinder Head Bolts - $10
30. Valve cover - $20
31. Alternator - $25
32. Oil Return Tube - $5
33. E34 Coolant Passage - $8
32. Starter - $15
33. Distributor and Rotor - $10
34. Distributor and Rotor - $10
35. Timing Belt Tensioner - $8
35. Vogtland Springs - Good Shape used for 10k SOLD!
Thanks!!
Jeff
4. Oil pump - $30
5. Block - $80
6. Crank - $70
7. Pistons -$40
8. Intake - $35
10. Fuel rail - $10
11. Injectors - $40
32. Starter - $15
