Getting ready to move, time to liquidate my parts. My prices should be fairly reasonable, if not, I can work with you. Shipping will be actual cost via USPS or UPS depending on size.
Let me begin by saying that in addition to the parts listed below, I also have a complete 86 ES that I am willing to part out as well. So if you don't see something you're looking for, just ask!
Getrag 260, 300K+ miles, shifts good but could use some fresh fluid $100 SOLD
driveshaft, manual, needs CSB, joints good $50 SOLD
driveshaft, auto, good $50
halfshaft, needs boots, minimal play $20
oilpan (2) $50 BOTH SOLD
e34 525i radiator, possible to retrofit $20 SOLD
Turbo manifold, unknown brand, quality seems very good...was gonna be part of my next project...$200 SOLD
Steering wheel in nice shape $20
Evaporator, some bent fins but perfect working shape $40
Factory amp, works great $15
Radio antenna, both work $15 ONE LEFT
airbox $10
"082" AFM, both good $25 each SOLD
ignition coil $10
center console $5
e-brake boot $2
door seal, coupe $5
throttle body, i $20
throttle body, e $10
airbag control unit $5
fuel rail, e, i, m52b28 $10 each
crankcase breather tube $2
e28 motor mount arms $10
e30 motor mount arms $5
b25 wires, one set missing a plug $5, other set good $20
cap/rotor in various condition $10 for the best
b25 intake manifolds, bare $20
complete with injectors, rail, FPR, wires $40
Valve covers, $10 each ONE LEFT
i valves, complete set $80
2 intake, 1 exhaust $7 each
e valves, complete set $50
i double valve springs, (2 or 3 sets), $15
valve keepers $5?
rocker arms, complete set good shape $50
rocker arms, 9 in ok shape $5 each
rocker arm shaft, (several sets) $10?
rocker arm retainers, (several sets) $5?
cam gear, $5
TPS $5 SOLD
cam seal guide piece $5
i camshaft, (2) in OK shape $40 each
ABS control unit $15
mirror $5
timing belt cover (2) $3
vibration damper, e, i $5 each
oil sprayer $2
oil pump, $15 SOLD
exhaust manifolds $10 set
washer fluid res $15
kidneys $5
fan, e $5
brake calibers, front/rear $20
window motor $8
other various brackets and gizmos....make offer
wiring harnesses...
b25, missing one plug $20 SOLD
b27, $10
m52b28, $30
check control panels $5 each SOLD
check control blank $20
washer fluid level sender, new $7
washer fluid pump, $4
e21 radio, no code $30
Glovebox, nice shape, one small dent lower left, hardly noticeable $40
b27 pistons $10
b27 rods and pins $10
b27 crank $60
alternator, $30
b25 block, needs a rebore (grooves in cylinder wall), everything else ok.
b25 pistons $20
b25 rods $20
b25 crank $40
other misc stuff...
2-door pop-out rear glass $20
steering column $20 SOLD
e coolant reservoir $5 SOLD
brake booster/master cylinder $20
AC compressor, unknown cond $15 SOLD
trailing arms, $40
power steering pump/reservoir $20
m52b28 valve cover?
4.10LSD with 180k on it...could use new seals and its a bit rusty from sitting, but otherwise its good $150
Sport seats that need a complete rebuilding $100 SOLD
Black vinyl rear seat from 2-door, great cond $40 SOLD
oil cooler $50
injector sets....$10
173 DME ....$50
Mark D 19lb 93Oct copy...$50
Will probably be adding some other stuff soon as well.
If you have any questions please ask!!
ignition coil $10
center console $5
e-brake boot $2
door seal, coupe $5
valve keepers $5?
cam gear, $5
TPS $5 SOLD
mirror $5
oil sprayer $2
oil pump, $15 SOLD
kidneys $5
fan, e $5
window motor $8
wiring harnesses...
b27, $10
m52b28, $30
b27 pistons $10
b27 crank $60
alternator, $30
b25 pistons $20
b25 rods $20
b25 crank $40
other misc stuff...
trailing arms, $40
m52b28 valve cover?
oil cooler $50
173 DME ....$50
