I need to clean up my storage area.. I have so many parts..here's a list of the parts I went through so far.. to view through the pictures
Here's a list of parts I've already went through. I've got so much more I'll have to add them soon...
Please click below to view photos
Prices are before Shipping...
Heatercore $25, 0001,0002
Idle Control Valve 325i, $25, 0003
Air Flow Meter 325e #0 280 202 091, $25, 0004
Headlight Switch e30, $5 0006
Gas Tank Actuator 51.26 1 372 572 $5, 0007
BMW e30 Air Recirculation Actuator $5 0009
325 badge $7 0010
Hazard Switch e30 $6 0011
Power Mirror Switch $5
0013
Passenger Inner Door Handle $5 0014
Speaker Fader Switch $4 0015
Oil Pump e30 $20 0016
Power Window Switch $5 0017, 18, 19, 20
Lamp Control Module e30 $5 0021
Interior Light E30 $5 0022
0023 Lamp Control Module e30 $5
Door Handle Trim $4 0025
Sunvisors $20 0026
Tan Door Armrests $20 0027
HVAC Control $30 0028
Passenger Power Mirror $10 0029
Low + High Horns e30 $10 0030
Right Inner Door Handle Passenger $5 0031
Power Steering Reservior $5 0033
Hirschmann Power Antenna 6000EL (I've got like seriouslly 10 of these I've got to test them all
0035 325e Coolant Tank w/sensor $10
Outer Door Handle $5 0036
0037 Outer Door Handle $5
0038 Spark Plug Wires (i) 88-91 w/sensor $25
Valve Cover $10 0039
Early Turnsignal Cover $4 0040
Mass Airflow Sensor 325i #0 280 202 082 $30 0041
0042 Mass Airflow Sensor #0 280 202 082 $30
Throttle Body 325e 325es #0 280 120 301 $20 0043
0044 Thorttle Body 325e 325es #0 280 120 301 $20
325e Fuel Injectors #0 280 150 126 $25 0045
Fuel Pressure Regulator 2.5 bar $6 0046
325e Idle Control Valve $30 0047
Black Front Kick Panels $15 0048
Washer Pump $5 0049
Cruise Control VDO Relay 412.205/004/003 $10 0050
various BMW Relays from e30 $8 0051
Cruise Control VDO Relay 412.205/004/003 $10 0053
325e 325es ECU #0 261 200 027 $40 0055
Diving Board Turnsignal $6 0059
Throttle Body #0 280 120 310 325i $20 0060
Windshield Washer Bottle $5 0061
Fuel Rail harness $5 0062
Washer Pump $5 0063
Ignition Coil $10 0064
Injector frame $5 0065
Radiator Support Plastic Bracket $5 0067
License Plate Holder early style $10 0068
Fan Blade 9-fin $10 0069
325 badge $7 0010
0013
Sunvisors $20 0026
Washer Pump $5 0049
Washer Pump $5 0063
